FedEx Santa just dropped these off, I was hoping to have these installed for Johnson Valley after Christmas, but all the parts never came together. These are the standard replacement Rock Jock 60's. The front uses the stock JK knuckles, hubs, brakes, etc. I originally wanted to upgrade the front housing since it is bent, I dont know how that could have happened, it is a 30 and I want to run 37's. A Rubicon 44 would not have had any axle housing strength benefit since it still only has 2.5" axle tubes. I wanted to keep the stock knuckles and outers since this is one of our R&D jeeps and wanted to run an off the shelf tie rod, drag link and we plan on doing some brake upgrade kits, also I can keep the speed sensors to make the ESP happy. The front is uses 30 spline chromoly Dana 44 inners and will use JK 30 outers or the Superior chromoly outers that use the 760 u-joint. Currie plans on making a 35 spline inner with the bigger JK Rubicon u-joint but they were not available yet. These will get ARB air lockers and upgrading the side gears later will be an option.
The rear end is also the standard JK replacement rock jock, it uses 35 spline axle with the speed sensor tone rings and 5 on 5 or 5 on 5.5 bolt pattern for the wheels. The rear will also have an ARB air locker and 5.38 Yukon gears.
