1 - 12 of 12 Posts
I have a crashed 2013 2 door white sahara and i need the following
I need
Front bumper
Front axle Dana 30 with 321 gears
Steering pump
Left front schock tower
both front fenders and grill with paint able flares.
windshield
left front door glass.
Screen or Nav unit mine is cracked
rear seat for 2 door, sahara black.
I will pick up in the New York Tri-State area.
Let me know what you have
Yes trying to get a stock Dana 30 with 3.21 complete cheap as a drop in to replace the bent one. All the ones I see are cheap $200 to $300 but are on the west coast so it costs that again. How much do you want for the shock tower?
When will you have it?
Sahara Dana 30
I have a sahara Dana 30 with bad spider gears and 3.21 gears that I would let go for $400 if you want to pick it up. I live in Painted Post NY. It's not bent as I just replaced it with a Rubi 44. :)
If I remember right changing out the spider gears isn't too big of a deal! But I could be wrong.....
Not hard at all, pull the carrier out, ring gear off, cross pin out, replace spider gears, put back together in revers order.
Can you post some pics of the shock tower and what exactly needs to be replaced? I dont mind taking a little extra time to cut it off carefully but want to make sure it will work for ya.
1 - 12 of 12 Posts
