Damn!!!! $1000 for a hard? That's a steal a should sell quickly at that price.
Op, If you want to make the drive to Colorado I would be happy to fix it for you for nothing. Ive done a ton of composite work and your crack shouldn't take much material.
The resin they use in these isn't great so your repair resin needs to be epoxy. A good quality generic epoxy would be west system and that could be available from west marine . Com. I would fix that by lightly scoring the onside of the crack into a "V" and cut some 4oz s glass onto three patches getting slightly bigger with each patch, about a half inch.Scuff the area to be patched with 80 grit, wipe with alcohol(NOT acetone or mek) paint some resin on there with a brush and stick your smallest patch on. Dry. Poke at it with the brush and when it starts to turn clear put the next piece of cloth on and do the same and so on. Use the resin sparingly, only enough to get it clear.
This could be done with the top right side up but flipped over is better and for a really smooth surface after your last patch you can hot coat or paint some resin over it and that will stop the edges from curling up a millimeter or so. Its possible that with paint it won't even be noticed. I wouldn't do anything to the outside except maybe draw a sharpie down the crack to hide the white.
