1 - 10 of 10 Posts
I just installed my Rk front lower control arms, 3.5 springs and Rk adjustable track bar and Extended swaybar links.
I gots serious death wobble.
I realize my lower and upper trackbar holes are a little sloppy, So last night i ordered the poly upper and lower bracket and a new steering stabilizer.And i have been driving slow to not have more issues of wobble.
The question i got, is now that i have driven to work a few day's. Should i be able to unbolt my front lowers at the axle end and adjust it and just swing it back up in and have it line up? What i mean is it was kind of a pain in the ass to get them in on Sunday as far as lining up at the axle bolt. SO i am wondering if maybe they were set to long/short ????
I went by the measurement on the Rk instructions but honestly i am not sure what i should be looking for as far as adjusting them??
Would take any pointers or advice .
Discussion Starter #2
Bump...
You should be able to add a turn out on the lower Krawler joints and gain a little bit of caster. You can adjust one arm at a time and use a bottle jack under the knuckle to torque the axle to get the arm back in place :)
The eye to eye measurement is that from inside edge to inside edge or center to center? I did mine from inside to inside...:shaking:
Discussion Starter #10
It is center to center!
RK
That would explain why it was a pain in the ass to get them lined up when i installed them...:bawling:
And now that i look, I can see the bad angle on my drive shaft. :shaking:
Thanks to all for their help.:beer:
1 - 10 of 10 Posts
