1 - 2 of 2 Posts
I got a free compressor from work (out of a O2 genorator) not sure if it would make for good on board air ..here is the specs .
.it is only 40psi max press but it looks to have a good flow rate and low currnt draw....(compared to some other on board that I have looked at) I have no knowledg in this so any help would be great.:beer:
and it was free so cant beat that
Operating Mode
Pressure
Medium
Gas
Pressure Flow Rate 0 pressure
4.6 cfm
130.3 l/min
Max. Pressure Continuous
40.0 psi
2.8 bar
Max. Intermittent Pressure
40.0 psi
2.8 bar
Max. Pressure Restart
Energy Supply
AC
Voltage
115V
Frequency
60/1Hz
Motor Rating
608.0 W
Current Drawn
5.3 A
Motor Type
Permanent Split Capacitor
Motor Protection Class
B
Speed
1675 rpm
Weight
17.60 lb
8.00 kg
Ambient Temperature, min.
50 °F
10 °C
Ambient Temperature, max.
104 °F
40 °C
Average Noise Level
Stroke
0.48 in
12.2 mm
The missing number is air flow at max pressure, because that is where it will need to operate to be of any good for anything...barely airing up tires, not high enough for reseating bead, lockers or air tools...
1 - 2 of 2 Posts
