Welcome to the forum! How many miles are on it? OE Spark plug gap is .043, I'm not sure if that matters with the aftermarket coil packs. It might be worth looking into further. Did you check fuel trim?
Thanks @dermarpaintWelcome to the forum! How many miles are on it? OE Spark plug gap is .043, I'm not sure if that matters with the aftermarket coil packs. It might be worth looking into further. Did you check fuel trim?
Thanks man! Ill double check. Im at witts end and willing to do anything. lolYou're welcome. Anytime you get into those kind of mods there's a lot of areas of gray, and OE specs can go right out the window unfortunately. Over the years I did troubleshooting for problems like yours and once or twice plug gap was the issue. Having said that your situation is different, I would ask around about the plug gap, and double check for vacuum leaks. Good luck!!
Ask around about the plugs gap and type first, taking them out is a bit of a PITA. But I do question the gap. Double checking for vacuum leaks is easy.Thanks man! Ill double check. Im at witts end and willing to do anything. lol
