Code P06DD question, oil pump or oil cooler assembly... help!
1841 Views 7 Replies 3 Participants Last post by  spottyj
Hello everyone, I have a P06DD question to put out there. My 2012 2 door:
Wheel Tire Vehicle Automotive parking light Automotive side marker light
has the dreaded P06DD code, "dual stage oil pump stuck low." I've read probably 90% of the threads out there on the issue, and for starters, after reading all this material, I tried the two basics of verifying correct oil and filter.
With the code persisting, I then installed a mechanical oil pressure gauge, and the oil pressure is always within spec (around 20 psi warm @ idle, up to 60psi @ 3500 RPM. The engine does cut out, but only sometimes, at 3500 RPM, which fits with what the code is saying, i.e. that the PCM is limiting the RPM's to protect it the engine when higher pressure is required.
So at this point, I have narrowed it down to either the oil cooler assembly/ oil pressure sensor and/or the oil pump and solenoid. From what I understand, there is no reasonable way to test either one, you have to just dig in on a Saturday and replace one of them, while praying the whole time that will solve the issue. I am prepared to replace both if I have to, but herein lies my question:
Which one, oil pump or oil cooler assembly, is most likely to be the problem? I'm leaning towards the oil cooler/ pressure sensor because the engine cutout @ 3500 RPM is inconsistent, but I realize that might be faulty reasoning and have nothing to do with it.
Thanks in advance, any advice is greatly appreciated!
  • Like
Reactions: 1
1 - 8 of 8 Posts
^^^ This should help!
Thank You Old Dogger! I will check that resource out and report back.
  • Like
Reactions: 1
That was a helpful resource from Old Dogger, nice concise summary of all that material out there on the interweb about this pernicious code that seems to evade even the most meticulous of dealership mechanics. It also confirms my plan, i.e. to first replace the oil pressure switch (and oil cooler assembly since mine is leaking), then move on to the oil pump assembly if that doesn't solve the problem. As I side note, I have checked all the wiring for cracks, broken wires etc as best as one can, didn't find anything there.
After much deliberation and some looking into it online, I decided to go with the Ransoto oil cooler that comes with the pressure switch (I might swap out the pressure switch it comes with for a Mopar one just to be safe). I ruled out getting an OEM or Dorman oil cooler assembly due to cost, and the Ransoto has been getting decent reviews, comes with the sensors and gaskets, and is available at about 1/4 of the cost. i anticipate skepticism or even criticism for not buying US made, but I have a family and a budget I have to honor while I continue to indulge in my jeep habit.
I'll post back with the results in case narrating this process helps someone.
Ok well, thd good new is that I have shiny new oil cooler installed that doesn't leak. And also there's also a new set of plugs in there, it was time and I figured why not since I had the top off. The whole process was surprsingly easy, only took about 3 hours start to finish, including the plugs.
The bad news is, the CEL light popped on as I pulled out onto the road, with that spine tingling little "ding" that basically says, "you're attempted repair and all those hours failed to fix the problem." Same PO6DD code, I guess I should be thankful that no additional codes chimed in.
Not that these will really help anyone, but a few photos for reference.
Old cooler in:
Hood Vehicle Motor vehicle Automotive design Automotive air manifold
Blue Gas Electric blue Plastic Auto part
New one in:
Motor vehicle Vehicle Car Automotive exterior Automotive design
Motor vehicle Automotive tire Hood Automotive design Automotive exterior
Frustrating, this whole process. I will now move on to replacing the two stage oil pump solenoid, hoping that takes care of the problem.
Unfortunately, I just dishearteningly read a post from some poor soul who had his JK into the dealer a full 7 times to fix his P06DD, and it still wasn't fixed. He had literally tried every recommended fix for the problem, and his engine was still cutting out violently in the higher RPM's with the code tenaciously persisting. If the new Dorman Solenoid doesn't fix my issue, not sure what the plan will be.
Jeep runs alot better with new Bosch iridium plugs in BTW. I hadn't done them since I've had it, so who knows how long the existing NGK set was in there. Evidently they were past their prime.
  • Wow
Reactions: 1
Just put in the new solenoid this morning. Pretty easy job, only took about 3 hours, including the set up time for the oil pan RTV. On that note, I used the Mopar 3 bond:
Drinkware Automotive tire Fluid Liquid Drink
Old solenoid:
Electrical wiring Gas Automotive lighting Wire Electrical supply
New one:
Circuit component Electrical wiring Electronic engineering Gas Cable
Installed:
Motor vehicle Automotive tire Vehicle brake Rim Auto part
Here's a few thoughts about the process if it helps anyone down the road. The whole job is really straightforward. There were a few things I thought might be worth passing on.
1) the oil dlpstick bolt. I've seen where people take the front passenger tire and splash guard off to get to it. It is hard to get to, but you can get a 3/8 13mm socket on there without taking all that off. Helps to have a ratchet with a hinged head, but it is doable. Break it loose then you can fiddle it off with your fingers if it's not too rusty. A finger ratchet works if it's loose but sticky.
2) I've seen people fight getting the oil pan off because the original Mopar 3 bond is quite adhesive. There's an ear sticking out of the oil pan on the front passenger side corner of it. You can see it if you look down through the engine bay. I stuck a 3' long wooden dowel down through some gaps around the alternator, rested the tip of it on the ear, then tapped it nicely with a 5lb sledge hammer. The pan popped right off.
3) Loosen the oil pump to pass the new plug and wire between it and the block. I left one bolt on the far right corner, took three off, and it hung down just enough to pass the plug through on the left.
4) Wire insulation. The wires coming off my solenoid had lost insulation where the christmas tree/ zip tie retainer holds the two wires onto the engine block, just past the plug. The copper was exposed there, and also the insulation was cracked and missing where the wires exit the solenoid plug. I thought for sure I'd found the PO6DD problem right there, but a continuity check verified that the wires were still intact and carrying current. The made me wonder about the condition of the wires further up. Main point here, check the wiring carefully wherever you can, especially in those two spots.
5) the most tedious thing was getting the new solenoid plug back through the block. You have to finnagle it up into a small cavern, past the left of the timing chain, where the hole is on the left, about 5 inches up. No room for fingers unless you have long thin ones. Making it harder is that the front axle is directly in your line of sight as you look up into the block, so you cant see up in there to line the plug up with the hole. You basically have to go by luck and feel. I ended up getting some super long needle nose pliers to grasp the plug with, and after about 10 annoying minutes of finagling with it, it finally went in.
I am now waiting for the 3 Bond to dry. Going to put oil in tomorrow, fire it up and see if that (insert expletive here) code is gone. I will post results.
As I was laying under the jeep waiting for the RTV to set up, I was remember all the negative comments people make about the complexity of jeeps nowadays as they doggedly try and hunt down elusive electrical problems and fix codes. I think it actually might be a good trade off. My jeep has almost 200,000 miles. It doesn't burn any oil. It starts immediately, every time, no matter what the weather. It runs perfectly, always. It has the same amount of power as it did in 2012. It drives beautifully on the freeway even with the lift and 35's. It's comfortable to sit it. It's safe for my kids and wife to ride it. I've owned four Cj-5's, a CJ-7, a YJ, and two 4.0 Tj's. The CJ's were just miserable to drive on the freeway, and I would never take my kids in those rigs on any long freeway rides due to safety concerns. And the CJ's certainly didn't last 200k miles without alot of work. The Yj and Tj's were better, and lower maintenance with higher durability, but still uncomfortable to drive on any long trip. The JK is far beyond above all of them, in every area. Is it a pain to deal with all the wires and computers and solenoids? Yeah, but all in all, definitely worth it. Why am I sharing this here? No idea.
  • Like
Reactions: 1
Update, the new oil pump solenoid fixed the PO6DD. CEL is off and oil pressure is within spec at all RPM's. I've put a few hundred miles on it since the fix and no recurrent issues.
It's hard to recognize my dash display without that stupid engine icon lit up. What a relief.
One piece of data about the oil pressure system performance that I hadn't come across, and noteworthy here perhaps: The dual mode system runs in high pressure until the engine gets up to operating temp, i.e. around 90 to 140 psi. Once it warms up, I am idling at about 35 psi, up to 60-80 psi below 3500 RPM, then 80-140 psi at RPM's above that. Good to have it working again. It's probably in my mind, and also a result of the new plugs, but I swear it runs better even at lower RPM's, with the oil pressure problem fixed.
Finally I wanted to give a shout out to Old Dogger for offering a response and help, much appreciated. Hope this thread helps some other folks down the road in dealing with the PO6DD issue.
  • Like
Reactions: 2
Well written post, thank you for sharing.
  • Like
Reactions: 1
1 - 8 of 8 Posts
