Clayton Off Road has just released their 3.5" and 4.5" JK short arm suspensions. They're available for purchase on our website at the following links:
http://www.redrock4x4.com/shop/products/2898.html
http://www.redrock4x4.com/shop/products/2899.html
In addition to the complete suspensions, Clayton is also offering all of their components individually. Here's a complete list of all the JK products Clayton has available at this time. Most of these items are on our website already:
JK Hard Arms
CA-JKCAK JK Arm Complete Kit (8 adjustable control arms) $1,175.00
CA-JKFCAK JK Front Control Arm Kit ( 4 adjustable control arms) $575.00
CA-JKRCAK JK Rear Control Arm Kit ( 4 adjustable control arms) $625.00
CA-JKFLCA JK Front Lower Control Arms (2 adjustable arms) $355.00
CA-JKFUCA JK Front Upper Control Arms (2 adjustable arms) $245.00
CA-JKRLCA JK Rear Lower Control Arms (2 adjustable arms) $265.00
CA-JKRUCA JK Rear Upper Control Arms (2 adjustable arms) $375.00
Coils
CO-JK-F-3.5 JK 3.5 inch Front coil springs $149.00
CO-JK-R-3.5 JK 3.5 inch Rear coil springs $149.00
CO-JK-F-4.5 JK 4.5 inch Front coil springs $149.00
CO-JK-R-4.5 JK 4.5 inch Rear coil springs $149.00
Brakelines
BL-B-JKF JK DOT stainless steel brakelines, Front pair $79.00
BL-B-JKR JK DOT stainless steel brakelines, Rear pair $79.00
Adjustable Track Bars
TB-JKF JK Front adjustable trackbar (3-5 inches of lift) $189.00
TB-JKR JK Rear adjustable trackbar *** requires DB-JKR $189.00
DB-JKR JK Rear trackbar bracket (3-5 inches of lift) $119.00
JK Components
SBL-JKR - JK rear adjustable swaybar link 3.5-4.5 inches of lift $75.00
BS-JKF - JK front bumstops with hardware (pair) $39.00
BS-JKR - JK rear bumpstops with hardware (pair) $39.00
Any questions feel free to ask.
Discussion Starter · #2 ·
2007 JK 4.5” lift suspension system with 37x13.5x17 Toyo Open Country MT’s on Walker Evans rims
Clayton Off Road’s JK suspension lift systems are designed to give a smooth ride both on and off road while maintaining excellent handling characteristics. Our 3.5” system is designed to let you run a 35” tire and our 4.5” system is designed to run a 37” tire. These are complete bolt on systems and can be installed using basic shop tools. Our systems include eight adjustable control arms, which carry a lifetime, no questions asked warranty against bending or breaking. The lower front and rear upper arms are dog legged for tire clearance. All of arms feature either Currie Johnny Joints or Clevite mechanically bonded rubber bushings. An adjustable front track bar and rear track bar relocation bracket are used with our systems. An optional adjustable rear track bar is available for use with the rear track bar relocation bracket for fine-tuning the rear track or to allow pinion angle adjustments when using a CV style drive shaft. JKS front sway bar disconnects, rear extended sway bar links, front and rear bump stops, front and rear extended brake lines, and 3.5” or 4.5” coils springs are supplied to complete our lift suspension systems. Shocks are sold separately and Bilstein 5100 shocks are offered as an option with our systems.
It's funny how companies come and go? These guys haven't been active on here since 2010.
