1 - 20 of 20 Posts
I dropped my Rubicon off on Monday morning to have Clayton Offroad Manufacturing's 3.5" suspension lift installed. The shop, Caldwell Automotive in Carrollton, GA is the shop I chose to install it. I have had them do a few smaller things for me and they've done a good job and charged me a fair price.
The lift is still in the process of being put on, but it was almost complete this afternoon when I picked up the tires and wheels for another member. They need to bolt up a few remaining things, test things out, and then get it aligned. So by tomorrow afternoon I should have her in all her glory.
I'll have some additional feedback after I get to test it out and more pictures. Unfortunately, the camera died after the first picture. I took some with my cell phone, but they turned out really bad because of the lighting. I will definitely take more tomorrow.
The one comment I can make on the kit right now is that the shop felt there was enough rake to justify leaving in the 1" spacers that I had in there. I had added spacers a long time ago to the stock suspension, because of the weight from the Shrockworks mid-width bumper and Warn Power Plant (even with synthetic line and no roller fairlead).
thats gonna be nice when they get done! You got to get out on a ride with us sometime. Your Jeep would would do very well in our group
Believe it or not I've been watching the club's board. I am very few windows to go off-roading and the times have either been poor or I didn't have the budget for it. The wife doesn't protest much, and I want to keep it that way.
whats included with this kit? my frien ran the claytton long arm on his cherokee and it was great.
It's a complete kit less the shocks and rear track bar which is an add-on that I purchased. You get eight adjustable control arms, coil springs, front adjustable track bar, JKS front disconnecting swaybar links, rear swaybar links, monstrous rear trackbar bracket, bumpstops, and brake cables.
do you mind posting a link to the lift? Sounds like a good kit for sure. I am in the process of lift shopping.
Here it is:
http://www.claytonoffroad.com/index... List&l=make!model!modelEx&p=Jeep!Wrangler!JK
One thing else I want to add is that Clayton Offroad has been great to work with. I called them before purchasing and talked with Adam for over 40 minutes about general questions and concerns about the lift. I didn't get placed on hold or anything and he genuinely didn't act like he had anything better to do which I know wasn't the case.
I went into the conversation with him wanting to go for the 4.5" kit. He said that the 3.5" would be sufficient for 35"s and convinced me that route. I still wasn't sold and asked if there was an escape clause; i.e. I'd pay some type of restocking and shipping and get the larger springs. He did one better and said that if I kept the plastic around the springs when they were installed that he'd swap them out if I wanted the larger ones. Awesome service in my opinion. (And as you can see from the pictures the shop forgot that step, but that's not really the point.)
Thanks for the link! Ill have to put them on the list. I like the 3.5" kit but I do plan to go up to 37's one day so not sure if ill do 3.5" with flat fenders or just a 4.5" kit. Definitely post pictures when they are done.
The only difference between the 3.5" and 4.5" kits are the springs. It would be easy to swap them later. I think you'll want the 3.5" with 35s when you see these pictures...
Discussion Starter #10
And it's done. I completely love the look! It is exactly that I was hoping it would look like. First here is a before and after:
Here are more pictures of the suspension and drive lines:
There are more images here (I couldn't post anymore because of the picture limit rule):
http://www.flickr.com/photos/tgrt/sets/72157604849242802/
The Jeep drove really nice on the way home. The Nittos are loud and have an interesting tone, but I didn't find them too annoying. The ESP came on with one tight turn I made near the shop, but it wasn't a problem on other turns. I'm not sure if it's a problem or not.
I used the Hypertech Max Energy before I left the shop to set the tires at 34.75. I didn't want to mess with trying to make the chalk line and stuff while I was there. Additionally, for those that have Nittos on a 2-door what do you set your tire pressure at?
Here is what was added:
  • Clayton Offroad Manufacturing 3.5" kit
  • JE Reel 1350 drive shafts
  • Teraflex spare tire carrier adapter
  • Nitto Mud Grapplers 35"x12.5"x17"
  • Cragar Soft 8s 17"x8"x4.5"
I didn't get starting dimensions, but here is what I measured after the fact:
front, up to frame rail = 28"
middle, up to frame rail = 20.25"
rear, up to frame rail = 27"
height, top off = 76" (6' 4")
very nice! And i think you are right, the 3.5" gives a lot of room.
O and the PSI, I dont have the same tires but I am another 2dr on 35's and I usually run around 32 PSI cold on the streets. It measures more around 35 PSI on a warmer day like today...
G
Guest
I agree that the look is just right! That's a very cool looking Jeep. The tires really add a nice touch.
I have a 2 door with 35's (Goodyear MTRs) and run 33psi on the street. I haven't been scientific at arriving at that pressure, but it seems about right.
Discussion Starter #14
I took a little bit to run out to a local place to try out the lift offroad. Overall it performed really good! I was really happy with the flex and how stable it felt.
My driver's side shock boot slipped off. I just don't think it was tight enough. There was also a loud noise a few times. It seemed to come from the front end, and I think it occurred when the front end was compressed more. But, I'm not sure about that. I checked it out really quick when I got back, but I didn't see anything out of the ordinary.
Looks very nice, I hope to have the same setup within the next few months.
Do you have stock gears, and if so how do they handle the 35's?
Discussion Starter #16
I still have the stock gears, but I have 5.13s on order. For some reason they are backordered.
G
Guest
You might check to see if your front track bar hits the diff cover. I ran the Riddler front cover with my 3.5" RE kit and the track bar interfered with it on full compression. After trying several things, I ended up going back to the stock cover, though I'm sure there is a better way to solve it.
Discussion Starter #19
so i assume that means the stock gears suck with the 35's
Yeah, that's a fair assessment. I can feel a little more power from the Hypertech with the setup, so that helps make it workable until I can get the new gears in.
That looks nice! I love the color. You'll love the Nitto's. Best tire I ever used in Mud, Rock, whatever...cleans out quickly.
1 - 20 of 20 Posts
