Just bought a 07 jk. Over the weekend. On test driving it hit a pot hole and did the "death wobble". Dealer replaced the ball joints and did the alignment, rotated the tires. Apparently everything else was "fine" 90,000 miles on the jeep. It was very well taken care of. Looks new inside and out. But, this morning manual shifting from first to second the break was stiff and those three lights came on. Traction,abs, and one other can't remember. Stop at the sign to turn and shifted till thrird and they all went off and never came back.
What come it be? Read on here about sensors etc.
Make sure your steering wheel is adjusted straight.
Lights come on in the dash, you get a ding, tach drops to zero (with no change in actual RPMs) for a moment & then goes away. Happened to me when the steering was slightly off center.
FFS, it's not even Thanksgiving yet and you're turning on your Christmas lights!?
But srs. You shifted from 1st to 2nd THEN hit the brakes? The brakes then felt stiff and the lights came on? Then after a turn from a stop sign you shifted up through 3rd and they turned off?
Have you tried to pull stored codes yet? Any wheel speed sensor codes?
