Panamon Creel, thanks for putting that in terms this MCSE can understand!
Guess I'll throw in my 2cents on the diagram.
I don't care for the relay controlling all of your rocker switches. For one thing it's a bit excessive, but most importantly is it is a "all or nothing" system. As someone that has had relays fail and have replaced relays..If that relay fails, you have no lights. If that fuse blows, you have no lights. I would prefer to knock one of those variables out and just power all the rockers with a simple fuse. The current through that circuit will be FAR from requiring any sort of relay.
You also do not need to ground the relay 85's to the battery, any local mounting bolt/ground distribution is more than suitable and easier.
The 7.5a fuse for two 55w lights is not sufficient. At 14v (running) they should pull about 7.8amps, at 12v (just key on) they will pull over 9amps. The 20a fuse for two 130w Spots is also not sufficient. At 12v (key on) they'll pull about 22amps. The 15a fuse for the 200w circuits are not sufficient either, at 12v they'll want to pull about 17amps.
Go through and reconsider your fuse ratings, you want 10-15% higher rated fuses than expected in the circuit. Also consider just running small bladed circuit breakers; if something hiccups and it pops, you'll have your lights back on in a couple of seconds. I would definitely do that for the main 50a fuse feeding the distribution block.
Not sure if I just don't know what I am talking about or everyone just glanced at the diagram...but that's what I noticed.
I guess I should have prefaced my original post with, "I've avoided automotive electrical work like the plague prior to this so everything I'm drawing up here is based on what I've learned in the past couple weeks."
With that in mind, I've already eliminated that rocker switch relay from the plan based on usmcdoc14's and MoridinTX's advice. The rockers will be powered directly off either a TIPM tap or a tap in the cigarette lighter with an in-line fuse.
The 85's are grounded to the battery because everything will be inside a sealed case. Grounding to the battery just seemed easier since the PDU will be mounted right next to the battery and it will keep all the ground wires within the waterproof case.
Going back to my first paragraph (I'm a knuckle dragging moron when it comes to electrical) I guess I've had the wrong idea on fusing the circuits. I thought I was supposed to fuse the wire to less than its maximum amperage. So what you're saying is that I should fuse the 110W circuit with a 10A or 15A, the 200W with a 20A, and the 260W with a 25A?
And thanks to both of you for taking a look.
E-95
ETA: Oh, and I'm planning to use (again, on usmcdoc14's advice) 12ga from the PDU out to the lights and 10ga inside the PDU.
