Check engine light on, found two codes.
24 - Throttle position sensor voltage too high or low
46 - Charging system voltage too high
I erased them and only code 46 came back.
Anyone know what this could mean?
Only mods I have are windshield mounted lights(straight to battery) and a CB radio that was wired into my fuse panel-cigarette lighter fuse behind the glove box...my jeep is an 04 TJ sport with 70000km.
Either the Alternator is taking a dump or the sensor under the battery that sense's temp has gone bad & is causing the alternator to pump out to much voltage.
Check it, if its to high It will likely chew up the battery & possibly some electronics, most likely the fuseable link would go first though.
