Had to get rid of my nice TD Plasma Cutter when we moved to Colorado.:bawling: Haven't had one in almost 2 years.
Heard good things about this cheapo ebay one:
http://cgi.ebay.com/SIMADRE-50R-110...dZViewItemQQptZBI_Welders?hash=item3ca8184316
I don't usually buy cheap crap, but I played the "Best Offer" option and got it for $300 shipped, so what the hell.
It arrived yesterday and it looks to be pretty decent quality. But I'm a little confused. There is no plug on the power cable. The instructions are chinenglish, and me no hablo chinenglish. The diagrams appear to be for a different machine.
It claims to be a "dual voltage", so I was hoping it would be easily interchangeable, but the power cord is not easily removeable. The cord is about 3/8" Diameter.
Am I supposed to just wire a 220v plug to the 3 exposed wires(Red, Blue, Green)??
I want to fire up this beeatch and wreck some chit!:D
red/blue/green sounds like a 220 setup, most 110s are black/white/green
It says it works on dual voltages, so I'd think as long as you keep the green as neutral, it should be ok
I'm not much help on that one but if I knew you were lookin before hand I woulda suggested you go with an Everlast off ebay.
I bought one of their combo machines - plasma/arc/tig and it blew shortly after I got it, but they have a 5 yr warranty and they upgraded me to a heavier unit for free and its been great.
Plus they have a US distributor who speaks english and does tech support stuff.
So go buy a 50A 220v plug and wire it up?
The red and blue wires come with about an inch of the sheathing pre-stripped and soldered. The green is not stripped at all. So green is ground the others don't matter which prong they go to?
Also, there is a stud labeled ground on the back of the machine. No wires going to it from the inside, just seems to ground the body of the machine. The chong instructions say nothing about it. I never had to ground the body of my previous machine. What is that thing for? Isn't there already a ground when you plug it into the wall?
Sorry... I'm not very electro-intelligent. Don't wanna burn the house down.
Well, this is how it *should* go....
when you get the plug there will be 2 flat and one "round" prong (usually a rolled flat piece making it round) in the center
run the green one to the 'round' center prong and the red and blue to the other flat prongs
the ground stud on the machine, I've seen em but never used one before, my everlast has one and I don't use it, so does my wire welder
once again, assuming that it actually is a 220 capable unit, everything should be good
I ain't no fancy electrician, but thats how I've done it in the past and how I'd do it if it were sittin in front of me right now :beer:
O.k. Got it fired up and it seems to work as well as any other machine I've worked with.
One more question...
there is a little toggle switch on the face that has a 2.5s and 5.0s setting. The chinstructions have it listed as the "Gas Post Switcher".
WTF is this switch for?
NEVERMIND. Fingered it out!
