1 - 9 of 9 Posts
Let me start - I have a 2 year old...
NOW - I decided to let my son "drive Daddy's Jeep" while I washed it the other day... when I was done, I noticed I was missing some change (normally keep it in front of the gear shift. Today, as I am driving, I hear some "rattling" - my mind flashed back to two things:
1. The missing change
2. The fact that at the dealership, he "lost" a quarter down the AC vent...:eek:
:eek::confused:
Does anyone have ANY idea how to get the change out? :rolleyes:
Hammer
PS. It may be in the center console, but that appears easy to get to - just those two bolts on the side, right???
In the center console its easier than that. The rings surrounding the movable vents themselves will rotate and come off w/o tools. This should allow you to get into where your son stowed his change.
As for the outers... I haven't tried to take them off but I'm sure that the procedure is similar.
Good Luck ;)
yup, all the vents are half turn of the bezel and pull to remove.
Just watch when you put them back, they only fit one way, theres a 'top' and a 'bottom'
as far as if you can reach all the way to where the change may have ended up, I dunno, never tried.
Good Luck!
Update
OK - I removed the center vents, nothing in there (think the silly hill I live on may have contributed to gravity's affects)... found 3 coins on the floor mat - 3 left to find... I can hear them sometimes... man... this is nuts... SO WORRIED that I will have to remove the "black box"...
OH CRAP - just thought of this, any chance one of those rascals can get caught in my blower motor???:bawling:
maybe try a shopvac with small diameter hose ,just a thought
Plenum?
OK - I got most of them out - I think I am only missing one... down side is, it is in the heater plenum (I think that is what it is called). I can hear it sliding around in the "box" on top of the tranny tunnel, behind the console...
How hard is it to get to part???
Do I stand a chance?
Hey Hammer,, just leave the coins in there, then add more everyday & you'll have this:....
A
Guest
All my spare cash is already in the Jeep. This is my piggy bank now :bawling:
1 - 9 of 9 Posts
