I have a problem with my CB, every time I transmit, all the CB's on the same channel get a squeal, like feedback.
I receive everything clear.
SWR is 1-1.1 through all 40 channels(when I set the antenna, haven't checked since the problem)
Running 18 feet coax, a heavy duty spring mount, 4' firestick radio is a uniden pro 520xl.
Checked all connections as well as the length of the coax for shorts/kinks.
I am getting power through the cigarette lighter.
What can be causing this?
I have a nice digital multimeter, but no SWR meter.
Temporarily swap cbs with a friend. That will eliminate your cb and mic. If you still have the problem, run power and ground wires directly to the battery. If you still have the problem, it is your antenna or coax.(not likely)
