Ok guys, I have pretty much everything done on with mounting and wiring my CB except for mounting the antenna (its already wired too). I have a question though... My antenna came with a stainless steel mount and its suppose to go in the license plate bracket but I decided to put it on my tailgate where I used the plate from swag offroad and removed the tire carrier. Does the antenna actually ground itself off of this plate? If so, would the painted surface of the Jeep plate on the tail gate hinder that? Or does it ground itself through the module where the power for the CB is grounded? Thanks in advance for any help...
i'm not an expert but i followed the following diagram for grounding the antenna MOUNT, not the antenna itself.....hope this helps, if not I'm sure more people will chime in
THIS IS FOR A FIRESTIK ANTENNA
i used a Teraflex spare tire mount. To ground it I shaved off a small part of the coating on one of the mounting holes and ran a wire through the tailgate and back into the back of the cargo area and grounded it to the tub (had to scrape a bit of paint off of that ground but it's covered)
you'll see the lower mount bolt has an "eye" wire connector mounted, then i put the wire in and crimped it close, then connected the other end to a good ground in the cab
Well thats the thing. All that Came with the antenna is the wire that connects to the module and then the mount.... Does that mean that it is grounded directly through the mount or should there be a ground wire included in the antenna?
I got the complete kit for the JK Ultra mount with the Cobra 75 from Cool tech LLC. Thats really all I know. lol Sorry.
These are the same parts I used for my Cobra75 install; except for the Cooltech lic. plate brkt. I mounted my antenna to my swing-away tire carrier. The mounting of the stud and coax "fire-ring" to the concealed mount should complete the antenna grounding; as long as you assemble the parts as shown in Indianajeep's diagram above (far right diagram); AND, as long as you are getting a good ground via the bolt that holds the lic brkt/housing to the tub. I would check for good continuity between the bolt and the tub. I believe that the wire with ring terminals shown in the picture of the kit on CoolTech's site is for grounding; but it shouldn't be necessary if you get good ground from the bolt metioned above. What do the instructions say?
I know this doesn't apply in exactly your situation, but for those mounting your antenna on a tire swing make sure it grounds back to the chassis. Since my tire swing is isolated by a thick plastic bushing from the bumper, I ran about 8" of wire with ring terminals between the two and screwed it in, so it has enough slack to let the swing run through it's full range without tugging on the wire. I rattle canned the terminals and screw heads black once they were installed to blend them in with the black powder coat on the bumper. It's pretty discreet and gives me a good ground.
