1 - 20 of 21 Posts
im thinking about getting this one at least im asking for a cb for christmas and im jsut wondering some of the different places i can mount the cb ive only had the doors off twice but when its warm and not rainy at all id liek to have a sturdy mount or some thing where it cant be stolen
http://www.quadratec.com/products/96080_11.htm
this is the only place taht comes in a pck with all the stuff if i see a mount better or more innovative than this one i might jsut put the parts together here and leave out their mount and btw what is their mount there is no pictures of it as in the location:)
yes i searches but i couldnt find anything and i only saw 1 behings a steering curtain or something idk what you guys got
i saw a thread with like 4 pgs or sumthin but i couldn not find it
You can mount a small CB like that one under the drivers seat. Works great if you mostly intend to use it on the trail rides where you don't change channels. Just a little problem changing channels when driving.
I built a similar antenna mount with just a flat bar and some nuts and bolts using the top surface of the tire carrier.
http://www.cooltechllc.com/jeep/jk_CB_AllinOne_kit.shtml
Or piece it together yourself. I've never ran their antenna mount, but I personally don't like my antennas mounted on the sides. I live in Michigan and many of our trails are tight and heavily wooded with branches grabbing at everything. A spring, or a flex antenna, will prevent damage, but it will still always be snapping around if mounted on the side. Mine is mounted using one of the tire carrier bolts and only sticks above the roof about 12 inches. Yes, it does get caught from time to time, but that's only is heavy cover.
I currently am running the 75 and love it. It's small, easy to use, and has all the features of many of the high end radios. It's even got weather!
I've had a couple different cheap radios and they are just that. They will get the job done, but that's about it. Many of the cheap ones dont' even have a place to plug in an external speaker.
Also think about security. Crooks don't probably know the difference between an expensive radio and a cheap one. They just see a nice radio and then break in to steal it. On a 75, the control box is mounted under the dash, and the it has a quick disconnect so you can actually take the radio out if you would like.
For the price, I would go with a 75. You can put together a 75 and a Cooltech mount for $166.
$90
http://www.amazon.com/Cobra-75-Hand...1?ie=UTF8&s=electronics&qid=1256349838&sr=8-1
$20
http://www.cooltechllc.com/jeep/jk_versamount.shtml
$25
http://www.rightchannelradios.com/wilson-cb-antenna-109/wilson-flex-cb-antenna-363.html
$13
http://www.rightchannelradios.com/m.../3-way-cb-antenna-mount-with-hd-stud-458.html
$18
http://www.rightchannelradios.com/coax-cable-72/firestik-cb-coax-18-feet-216.html
Add some time and some misc. wire to ground the antenna and you are good to go. Then find somebody with an SWR meter to tune it and you'll be happy and won't need to upgrade later.
I just looked it all up online real quick, but don't count out truck stops.
Some are pricey, but some are pretty good. I have a 3ft Wilson Flex antenna I just picked up to replace my rigid antenna that I paid $27 for at the truck stop. The HD mirror mount I listed says $12, but I think I paid more like $5. And coax listed is a brand name, but I got some no name stuff for less than $10 for 18ft. As for the radio, online is likely your best bet.
Drill the hole for the mirror mount to the size for the tire carrier bolt, and throw away the other half of it. I used some heavy gauge wire that I had to ground my antenna. I just used some waterproof spade connectors with a bunch of dielectric grease smeared on them at the antenna, and then ran the wire through the tailgate along with the coax. The ground wire is grounded to the body with one of the subwoofer bolts. Then ran the coax to the front under the carpet and/or under the plastic trim pieces so there is nothing showing.
I'm running a 75 and love it. I know a few guys that have the 75 also and it's a pretty good radio especially for trail BSing.
when you say mirror mount is that the rearview or a side view or am i totally confused can i see a picture of these mounts in use if any of yall have em?
It's a mount for a semi truck side mirror. It's nothing more than a clamp. You don't use the back side of it though and you will only use one bolt hole. Drill out the hole to the size of your stock tire carrier bolts and put a bolt through it there and it works perfect.
I'll try to get a pic of my setup, but it won't be till tomorrow now.
That's the same mount that I run...bro.
Discussion Starter #17
the antenna one?
cause i like that one :D
im trying to convince my dad that instead of buy an air compressor for the garage to jsut get the viair one for the jeep ohh im a little schemer arent i:D
Discussion Starter #19
i got the arizona mount too.
cheapo walmart cobra radio works just fine for me!
1 - 20 of 21 Posts
