1 - 20 of 25 Posts
Just Installed my Cobra 75. I called my neighbor who has a hand held and he can hear me,but I cant hear him. Any Ideas ? Its very aggravating and have double check all the connection. I thought the antenna might not be grounded correctly but I would think I would not be able to be Heard.
Check you squelch to make sure it's not completly turned down. If they can here you then you are connected properly!
I checked that already and messed with the squelch and still nothing.I thought that if he could hear me it was connected properly. Thanks for the reply,I'm still trying to figure it out.
Maybe your neighbors handheld isnt really transmitting even with that sometime handhelds don't work that great because some manufacturers turn the wattage down less than 4 watts in them to conserve battery power. Depending on where you live might listen around to see if there are people in your area that have a mobile or base unit and ask for a radio check. Just some other ideas....
When he calls me I hear my Radio cue or whatever you call it but no voice.
Grant you really know how to kick a man when he is down. Dude this is so frustrating.
BTW: AT LEAST I HAVE A CB :thefinger:
:laughing:
dude, i've been looking and trying to help ya.
So far, all i found was to check your antenna mount and i'm also looking here
http://www.fixya.com/Search.aspx?ctgid=89&_s=they+can+t+hear+me
found this too
http://www.cobra.com/downloads/manuals/75WXST.pdf
For technical assistance, please call our Automated Help Desk
which can assist you by answering the most
frequently asked questions about Cobra products.
(773) 889-3087
24 hours a day, 7 days a week.
and ohh yeah... you suck that you have a cb :thefinger: i'm jealous
Thanks for the Help Grant. I give up for tonight. :beer:
Make sure you properly installed your antenna mount. The center conductor cannot be grounded to anything or it will cause your whole jeep to become the antenna. Here is a link to show what we are running in Hawaii from Richie Rich.
http://www.stu-offroad.com/cb/cb_install-3.htm
It talks about ensuring you have a good ground on the base but keep the center clear of metal. That is why that small plastic washer is required to be installed correctly.
Hope this helps.
Can you switch to one of the NOAA weather bands (last button on the right) and hear anything. To rule out a bad speaker.
Ask him also to move around. 100 ft. or so from where he's transmitting now. Not necessarily closer to you, just a different position, sometimes it helps. Especially with a low power hand held unit. Think of your cellphone signal strength bars, "can you hear me now?" (Before some smart a$$ mentions it, I know it's different freq./technology etc.)
Also are you near any buildings? Normally you're better not being near one. But for some reason when I park really close to my garage door. I pick up more chatter. CB reception is weird like that.
Discussion Starter #12
I took of my rear tire and Tail lamp assembly and I mounted the antenna bracket directly to the Jeep,could this be the problem?
no exp with CB's except my 76 (which works btw :thefinger: ) but plenty of RF exp. The fact that you can transmit but not receive is a strange one, usually the Tx is the thing people have problems with. X2 on checking your neighbors handhelds Tx. If you have a wattmeter and some connectors you can hook one up to his antenna port and see if he's even putting out enough power. x2 on his location, 4-5W handhelds do not like being indoors if thats where he was. From my exp, getting no Rx would not be your antenna. Rx will not be effected much by antenna tuning or grounding issues. Hell you can receive RF with a fork and a tin can, or a stripped piece of RG58.
So that leaves the (EDIT speaker) or your neighbors Tx. Can you hear static with the squelch all the way down? that would rule out the (EDIT speaker). That's all the help I can offer.
you need to verify that it is actually your radio with the problem by getting a different one to transmit to you.
I sounds like you are receiving the "carrier" signal, but not the "voice" signal. My bet is the handheld is not transmitting properly.
Discussion Starter #16
I did the SWT or whatever meter and its @ 2. I drove around to see if I could hear anyone talking and no Luck. I have gone over theses instruction numerous times and;
I GIVE THE F*** UP!
Thank you,I feel better Now :beer:
2:1 isnt a very good SWR but you still should be able to receive transmissions. Reflected power only really effects your transmit power. Can you hear static at all?
Discussion Starter #18
I do hear static. I can also hear when my neighbor Cues the CB but no Voice.We tested his CB with another CB and his is working.
Bummer, trying some web searches only came back with a few obvious things. Make sure the switch is on CB not PA, make sure you have 13.8vdcm a lower 11.8-12.5vdc could cause problems, other than that, I dunno what to tell ya. Might just be a bad unit that needs to be replaced.
Call Cobra's tech desk, maybe something is set wrong and they can walk you through it.
From their website "For questions regarding Cobra Electronics and its products, please contact customer service Monday through Friday between 8 a.m. and 5:30 p.m. CST or the automated help desk, which is available 24 hours a day, 7 days a week. (773) 889-3087."
1 - 20 of 25 Posts
