I probably already know the answer to this question, but hopefully somebody can verify it for it.
Is there an antenna out there that gets good reception that won't go over the roof the JK?
Reason i ask. My jeep is garaged kept and i barely fit in the garage now. If i have an antenna go over my jeep i'll end up ripping it off by shutting the garage door and I really don't want to take off the antenna and put the antenna on every time i get in/out of the garage.
Short and good reception don't really go together. There are plenty of stubbies out there that work fine, but you'll have to spend some time setting it up. On my other rigs I would mount the antenna on the front fender or bumper. It still hit the door going in and out but once your in the door doesn't jack with it (unless you back in). If you really want to look funny find a 1/4 wave whip and mount it on the rear bumper; buy the tip holder that attaches to the windshield and bow the antenna forward. It will only rubs and doesn't catch anything.
Not exactly what you asked for but try the Wilson FLEX CB antenna. You can bend it up to 180 deg. and not worry about it breaking. It's made of Fiberglass and about 1/4" thick, like an "ugly stik" fishing rod. I run a 4' antenna it with a Cobra 75 and get a SWR of 1.3-1.4. The antenna sticks out above the roof about 1'.
I have mine installed on my license plate holder and can bend it out of the way to get into a parking garage; even if you forget to move it out of the way, you don't have to worry about it breaking. Also good if you have to valet and don't know where they're going to park your car.
Here it is upright...
Here it is out of the way...
The other option is use a quick disconnect. I allways thought the quick disconnect + the spring was a good idea. Give flexibility on the trail and easy to take on/off with your hands. You can also get the firestik 3ft. It fits in the back of the jeep under the storage cover (always with you and can't be stolen). It fits from sub to the other side and is never noticed. If you don't have sub, you may be able to go longer.
Quick disconnects:
http://www.walcottcb.com/accessories-quick-connects-c-28_354_446.html
Springs:
http://www.walcottcb.com/accessories-antenna-springs-c-28_354_445.html
Coax:
http://www.walcottcb.com/firestik-k8a-single-18-foot-coax-with-pl259-connectors-p-200.html?cPath=28_355_437
CB:
http://www.walcottcb.com/cobra-75wxst-remote-cb-weather-radio-p-520.html?cPath=340_377_379
Also, getting a ground can be a challenge. My mount has no grounding, so I ran a wire from the base of the antenna mount to a good ground in the jeep. I have the sub, so I use one of the sub mounting bolts, but there are lots of good ground locations. To attached the ground wire I bought a battery connector from Auto Zone and attached it to the coax threaded head.
Alright, more info than you asked for, but with those 6 items (CB, Coax, mount, quick disconnect, spring, ground wire) you should be go to go.
Hope that helps.
I took my antenna mount - I forget the kind it is - and flipped it. It's the mount that attaches to your rear tire carrier and is designed to go on the upper right hand bolt (2:00 position). I flipped it upside down and attached it to the lower left hand position (7:00 position). So now my antenna sits about 6" above my roofline (thereabouts).
It's a 4' firestick btw. Get the 3' firestick and you're golden. Hell, you only need reception for about a mile or so anyways - right?
