1 - 20 of 29 Posts
So i have my CB radio and I purchased a 3' firestick, ive got 20 feet of coax cable andnow i just need an antenna mount and im good. Once i get the thing tuned of course. So has anyone purchased one of these mounts?
http://cgi.ebay.com/ebaymotors/07-09-Jeep-Wrangler-JK-CB-Antena-Mount-Teraflex_W0QQcmdZViewItemQQ_trkparmsZ72Q3a570Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem260380362286QQitemZ260380362286QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I believe they also sell them on quadratec...but they are so much cheaper on ebay. Some professional feedback from people who already have CB's is what im looking for here...im a total newbie. Thanks guys.
I have that same mount for my 3' antenna. Works fine. I used a Dremmel tool to remove the powdercoating around all of the holes to get a better metal to metal contact for grounding.
It's a bit cheaper than that Ebay price if you exercise your JKOwner's member discount. ;)
Thanks so much for all the help guys. Can i purchase something like that on teraflex? I also need some sort of cigarette lighter adapter because I want to make the radio easily removable for when I park in a lot with the top down. Anyone have any suggestions about that? Can i just attach the CB wires to a cigarette lighter adapter? Anyone have that set up?
Yes you can, you just need to buy a cigarette lighter plug from Radio Shack or use one from some other piece of equipment you don't use anymore and attach it to your CB wire. Make sure you have an inline fuse to protect your CB and your good to go. I did that for quite some time with my Cobra 29
If you are into fabricating your own parts, it's pretty easy to make a bracket for the JK. I made two simple brackets to mount my ham antenna and CB antenna to the spare tire carrier. (And no brackets were available back in November 2006 when I got my JK.) The brackets I made are just flat pieces of steel bolted to the top of the tire carrier.
I would suggest that you forego the cig lighter plug and disconnect the power cable from the back of the radio when you get ready to remove it. Do a quality installation and just disconnect the the power and coax when you want to remove it.
I really like this design. So much, in fact, I'll be pulling my tire off tomorrow and cutting steel. The only difference I see is to use angle instead of flat stock.
Quick and simple. How did you ground it?
Interesting you ask about the ground. I don't understand what all the hoopla about grounding is all about...
Unless you install something wrong, the antenna is grounded through the shield on the coax cable back to the radio which is grounded through the power leads. I found no need to ground either of these antennas any more than that. The ham antenna (a Comet SBB-5, designed to be ground independent) tuned down to a SWR of less than 1.5:1 The CB antenna has a SWR of less than 2:1 on most channels. A CB only puts out less than 5 watts which is practically nothing. These numbers are just fine for everyday use. I'm not sure they could be any better anyway with the antennas sandwiched between the tire and the top.
I would just make your mount and try it out. You can always add a ground later. But in my experience when people start adding grounds to solve problems they are having, it is usually something other than the ground that is the root cause of the problem.
:beer:
I'm a big fan of good antenna mount grounds. So are antenna manufacturers.
Firestik's opinion
Firestik said:
The path to ground must be sufficient enough to carry the power being applied to the antenna.
I agree with their statement 100%!! My experience with a 5 watt CB is that the braided shield on a quality coax cable will provide this path to ground.
And adding a larger path cannot hurt either!
I used flat braided stainless cable for the rf grounding on my Landcruiser. Connected it to all the major body pieces, frame, engine, even the radiator (brass) but I had an HF radio in it.
I've been wondering about antenna mounts on the JK. Not much of a ground plane on it so I guess the HF is staying in the Cruiser, and I'll get a 2m antenna that does not require a ground plane. But I think I will still run a few pieces of that braided cable for g.p.
Can't stand CB anymore, I think I'll just get a handheld for the trail.
CB mounts on the tailgate are never going to give you satisfaction with the 11m band..I have a mount on the tire carrier for 2 meter and that works fine..(the tailgate is grounded to the tub with a braided strap..) I ended up installing the CB mount on the RH outside rear panel of the tub.. Had to make some holes but there is a counterpoise for sure..
I agree with jonb96150 and USAntigoon about the amount of grounding and RF isolation required to operate a quality radio system down in the HF bands in a Jeep. Lots and lots of work to get a clean signal.
But since I only want to use a CB to communicate with other Jeeps on a trail ride where you only need about a mile of good signal, just about any antenna setup will work. I have friends that just plug their CB into the lighter outlet and set a magnet mount antenna on an inner fender in the back of the tub.
I have tried to use a handheld CB in the past and found they just don't work very well. They cost as much or more than a small CB with a small antenna and are much more fragile. I have my CB mounted under my seat. It is out of the way and when we are actually on a trail ride I just drop the microphone over the center console or have the passenger do communications. This setup works great on trail rides.
For "real" communications or for emergencies, I have my ham rig which works very well.
Discussion Starter #17
Thanks for all the advice guys. I guess ill attempt to make a similar braket to what jdrogers did, save a little bit of money. Now to ground it, I guess I will just make another hole into it, and run a ground wire to the tailgate, then run some stainless steel braided cable to the car itself? Is that a good setup? What guage or type of wire should i use to ground it. I was under the impression the smaller the guage, the larger the wire, and the better it is for grounded.
Discussion Starter #18
And i currently have my cobra mounted next to the gear shift, but it makes it difficulty, actually impossible, to move the passanger seat foward for backseaters to get in. Does anyone have their radios mounted underneath the glove box? I think I might try to zip tie the bracket up there.
When I said braided cable, I actually meant braided strap as UsAntigoon (are you against goons or are you from Antigua?) pointed out. You want a flat piece of strap, as Rf grounding is based on the surface area of the strap.
No.. no.. This name is a blend of US with Antigoon (Druon Antigoon) was a mythical figure who used to live in Antwerp (Belgium) The City I was born..
1 - 20 of 29 Posts
