1 - 12 of 12 Posts
Is everybody pretty much running the teraflex mount, or are there other ones That I am having trouble finding?
made my own using some flat steel stock
bolts the same holes that the tire carrier bolts to.
Teraflex mount and 4' Firestik with quick disconnect here! I really like the mount and havent had any issues with it.
JKO Dickhead
Not sure if you are running the stock tire carier....if not check out member Imack606's free custom bolt on mount....pretty killer
I just drilled into the stock tire carrier and mounted the Wilson antenna right into it. Been fine for two years now and didn't cost me a penny :)
Interesting... Let's see a pic.
Anybody mounted a cb antenna on their roof rack? If you have a roof rack that screws or clamps into the frame, did you ground it?
Research, bro!
Are you getting a swing away tire carrier anytime soon? Quite a few have mounts built right into them. Where I put mine...
Already have the mopar one... I've read in quite a few spots not all the swing-aways are grouned well & that one is not grounded well b/c of the bushings/lube...of course you can always take the interweb as gospel. :)
True? complete crap? I know the antennas need to be grounded well, so I want to do it right from the start and it would impact my choice for location I think.
1 - 12 of 12 Posts
