1 - 8 of 8 Posts
Hello, I'm a newbie to the community. I bought my Jeep almost 4 years ago brand new from a dealer. I took it to the dealer a week ago to check why I didn't have any heat at all and my fan was running very loud. They discovered that casting sand was left in the engine and now had blocked the radiator and heating core. After a week Chrysler gave the dealer the ok to make repairs (replacing radiator, heating core, flush out engine). I know absolutely nothing about cars but I do know that sand + vibration = extremly abrasive action. I did some research online and what I read did not encourage me at all. There is talk about the engine needing to be replaced and that there will be ongoing problems with AC and heat. The dealer will not replace the engine at this point (it has 40,725 miles) and my Jeep is still waiting for parts after being at the dealership for a week.
I'm kindly asking for advice. I don't know where to go from here and it seems that the dealer just flagged me as a "difficult" customer because I want answers. I am a 105 lb small female so maybe they think they can push me around. Should I replace my Jeep? Has there been damage to my engine? What further complications will have? Should I ask for a new engine? Thank you!
I would take it to someone you trust or ask around and find someone you trust to check it out for you. From personal experience with Chrysler with my jeep I wouldn't hold my breath in getting a new engine, which is what should of been done IMO. My transmission went out on my 2010 JKU at 59,000 miles. I thought the lifetime powertrain would cover it. I checked and mine did come with the lifetime powertrain but since I was not the original owner it was nontransferable to me. Then they went on to tell me that the transmission cooler from factory is pretty weak and really needs to be upgraded to a bigger one to prevent the transmission from over heating. Even after telling me all that they still stuck me with the bill and I'm not talking about a stealership, I'm talking Chrysler corporate. I even asked if they would pay for labor or something, no go. So I ended up with a jasper transmission, which IMO runs better than the stock transmission I had in it and my mechanic added a bigger transmission cooler to it as well. Total cost was $2700, and it came with a 3yr 100,000 mile warranty. I never thought about getting rid of it, I love it to much to do that.
What year is your JK?
2011? Could be casting sand.
2012? Not casting sand, as the blocks are die cast. In this case, it's something else, probably coolant related, or sealant related.
In either case, I would not think you need a new engine. Lots of people have had similar issues with no problems after the engine has been thoroughly flushed out. (It may take more than one flushing.)
A JKO DICK
Google "cooling system sand jeep jk". It is not uncommon for early Pentastar JKs to have casting sand in the cooling system. I would only use the info found on JK-Forum for reference.
What is the source of the sand, when the block is die cast, no sand involved?
A JKO DICK
I don't know, maybe the heads? Never really tried to figure out why it was just another reason I found to avoid buying a 2012 when I was researching.
1 - 8 of 8 Posts
