1 - 11 of 11 Posts
Need a little help finding the torque specs for the bolts that hold the ring on the carrier and the spec for the 2 caps that hold the carrier in the diff. Thanks for the help
Should be in Yukons installation manual on their site.
PM sent,, also make sure you have right axle called out, front or rear, 44 or 30
Bearing Cap Bolts, ft. lbs for stock configuration
45
Ring Gear Bolts
80
My jeep is a 2013 with what jeep call "next gen dana 30" so im not sure torque specs from an 09 would be correct. Any one have a 2013 dealer service manual that wouldnt mind looking them up for me thanks.
'09 was also the "Next Gen"
so whats the correct torque spec????? both of the answers given are way off from each other.
60 ft/lbs. JK Dana 30. Read the chart for yourself.
1 - 11 of 11 Posts
