1 - 1 of 1 Posts
I have a 2011 JKU Sahara that was imported from Canada.Â* I'm trying to hook up a horn button on the dash because the steering wheel horn pad is too stiff to "beep" politely at someone, but I can't find the right wire to tie into under the dash.Â* Everything I found online says it should be a dark green/purple wire with a negative trigger.Â* I found a dark green/purple wire coming from the steering column, and probed it, but I got no trigger (positive or negative) when honking the horn.Â* Thinking maybe I didn't pierce the wire enough, I cut the wire and the horn still honks.Â* Could this be because I have a Canadian model?Â* (I know it has DRLs and some other electrical differences) Any help would be greatly appreciated!Â*Â*I'm scratching my head here...
1 - 1 of 1 Posts
