Here is a pic of "before" grooving:
Here is a pic after, these are wide grooves, like 1/4":
Here is a link to the groover that I have:
http://www.speedwaymotors.com/Van-Alstine-Instant-On-Tire-Groover-110-Volt,2674.html It works great. Only takes about 30-45 min to do a full set, although I didn't do as many cuts as Molshove.
People will do different patterns. The reason to do it is that when tires are aired down the gaps between the tread close where the tire contacts the ground. Different tires behave different. In general you can create more bite, better winter behavior, better water behavior, better flex over rocks. However, you have to be cool with cutting up expensive tires.
That's the same groover that we have...works great
We did our TSLs, as well...This may give you an idea if you want to cut further....they do serious work
I can snap some better pictures next time I'm at the shop, if you want
I will ask the im a dumbass question how do you know that your deep enough or too deep so that you dont weaken the tire
I always start my first cut a little deeper than I think I should, and only do a tiny, tiny bit, to see if I'm getting into the belts. IF I am, I adjust the cut a little shallower
:stirthepot:I had no dog in the fight but you guys know that some of you are angry with the OP right?
:koolaid:
When they are balding, not much to loose. When new tires, I just start cutting, then adjusting the tool to get the cuts I want. The tool is easy to adjust.
The tool is real easy to control. You only cut as deep and wide as you set it.
Molshove did a complicated pattern that I bet will work well.
I copied some other guys who had TSL/SX's.
Yeah, you can always call the manufacturer, too...it can be tough to get someone knowledgeable on the phone, but it's worth the time and research. After some looking around, I was able to find that, from Maxxis' mouth, the Trepador comps are safe at + 3/8" deeper than stock
He's got some info we want, we'll be mad at him at somewhere date.
The cutting knife adjusts up and down. I set my big cuts so the blade cuts, on the major grooves, deep, but leaves about a quarter inch above the depth of the factory depth. The tool has a guard so it does go to deep.
The only new tires we do are for the race cars. The more whooped tires you do, the more comfortable you get with really cutting into the tire. You can get down deeper than you would think, and a lot of them
I've got a tire siper/groover right now I borrowed. I am planning to go about half the depth of the lugs. I'm still not sure of a pattern yet, but I am thinking I will grove only the centre of the inner lugs, going straight across, and than a couple sipes on either side of the grooves (so one groove and 4 sipes per lug). For the outer lugs, I think I might just do a couple sipes on the inner part of the lug. Sound reasonable?
On what tires? I can't remember the "new" tread depth for my tires, but I know I was able to get within 1/32" of new after cutting mine. Like I mentioned up there, give a call to the mfgr and see if you can get a recommendation for max cut. Also, google image search your tire and "groove" and see what others have done, if they have. You'll get good ideas, and probably adjust as you actually start cutting.
