The time to modify the Jk has come and I'm starting with armor. I already picked up front and rear Solid diff covers. My question is...
Could I replace the Socket Head Cap screws(grade and material unknown) that came with the diffs with Button Head screw made of heat treated alloy steel.?
The reasoning, I think the Socket Heads will be rock magnets and get damaged real easily making removal very difficult. With the Button Head I think with the smoother head finish, and the hex opening having more protection around it, would work better. Only problem I'm having is I'm used to just going out and replacing all hardware with Grade 8 for strength. And I'm not sure if heat treated alloy steel will be strong enough for this application.
