1 - 10 of 10 Posts
Need some help, I installed the Bushwacker Flat fender flares on my 2007 JK and the LED side marker lights (both sides) dont work. All other lights work fine and the side marker lights worked on my Stock flares before this install. If it were a fuse then the other lights wouldnt work, Im guessing. I have power going all the way up to the LED board but lights dont come on. I even switched up the wires like the instructions say and still no power. Any suggestions? By the way the look awesome but I'm worried about not being legal. Thanks!
Check your connection, did you solder? Do you have a cold solder? Check your polarity, LED's will only work one way.
This may sound dumb, but don;t run the wires "same color to same color". Mine were opposite colors when hooking them up. pi$$esd me off cause I installed everything, heat shrinked, and mounted the flares before testing the lights. I missed that part in the destructions though.
I would double check the wiring again. ..esp where the bushwacker connections to the led are.
I just installed my fender flares last saturday and did the same thing. they were already on and secured before i decided to check to see if the led's worked and they don't. i'm so pissed. i'm going to take another look at it this weekend to see if i can get them to work. i already tried switching the connections around (after taking the fender back off and peeling away the glue). i'd prefer not to take them off again, but i paid $550 for them and i feel like i wasted money with the lights not working even though the fenders themselves look great.
Bush Wacker
Its the wires, I figured mine out. White to black and you cant just do one side and check them. They both have to be white to black or it wont work. Do know why they dont just put that in the instructions.
I ended up doing a special install where I soldered the OEM plug into the LED connections so that you can click the OEM plugs back together for install.
I then silicone sealed the plugs to be waterproof and vibration resistant.
I would recommend that others do the same.
Vendor
Call bushwacker and have them send a new set of adhesive for installing, I bought a used pair and installed them this way
hello..I'm having the same dang issue....I didn't finish the installation because I checked them first, thank goodness. I have done all these suggestions, but nothing has worked. Did you ever get your LED's to work...what did you do?
I have switched the wires, connected both sides, checked the fuse....neither led's work after all those were tried.
1 - 10 of 10 Posts
