I would do the following:
Front Dana 30 -
Artec Industries Truss
Artec Industries C Gussets
Artec LCA Skids
Synergy Ball Joints
Rear Dana 44 -
In regard to axle shafts, I would leave the front D30 stock shafts in there and weld the u-joint caps. Then go out and find a set of stock shafts to keep with you for trail spares. Tear the front end down while it's in the garage sometime when you have extra time so that you know what tools and steps are required if you have a broken axle on the trail.
I have thought of this. Are the D30 shafts common to brake on the trail (moderate to difficult non-buggy trails)?
If you're sold on upgrading the shafts go with something like G2 or Nitro that offer the larger ears with the Rubicon style HD u-joints.
Larger ears and Rubicon style HD u-joints? Can you provide a link to them? Also can I order everything through you when the time comes? Confused...
I recommend leaving the stock shafts in the 30 is because if you re-gear it, the deeper the ratio the smaller the teeth on the pinion and the more likely you are to have a pinion give way before the axle shaft. Ask me how I know.
Basically in the front if I run 4:88 or lower gearing my pinion will most likely go first saving the axle shaft from damage? I know the axle shaft is easy to do yourself but what about the pinion?
I would run Ten Factory shafts in the rear axle. They are available with the bearings, tone rings, seals, ect pressed on so that you can keep your stock shafts for trail spares.
Good idea, but what about Alloy USA? I would prefer to buy the best setup within reason up front and not regret anything later.
Another option, since you're going to do the OX lockers, is to look at running the 35 spline locker and replace the shafts at the same time. You'll be stout enough for most anything at that point.
You mean 35 spline rear axle shafts coupled with the 35 spline OX locker? Can you do a higher spline count in the front at the same time as upgrading to a locker also?
Marcus
