21 - 27 of 27 Posts
· Registered
Repriced my CO2 system (THis is strictly based on what I have found online, have yet to go to local fire supply or beverage center for a used tank)
15lb Aluminum tank-$89
Poly regulator-$40
Off-road air flex CO2 hose with tire chuck-$40 (If anyone knows of where to get a cheaper hose with chuck, let me know... I could not find one)
$169 total. Not to bad at all IMO. Still about $90 cheaper than the poly set up
· Registered
Would mounting this in place of my factory muffler be a bad idea?
If you off road, yes.
If you plan to use it there, yes. Co2 tank needs to be elevated at the valve to be used.
· Registered
At Topless for Tata's my girlfriend won a 50% off gift certificate for Powertank.
I ordered a 10lb Package B system a couple months ago, looks and works awesome. Had it filled at a local fire service place for $17.00.
The handle on the top and the mounting bracket are really convenient.
Total system OTD + Filling ~$265. That's with their adjustable regulator, quick disco's, hose, gauge + inflator, handle, boot, bracket, cover and black powder coat.
· Registered
Thanks...
Jeez Goody- you have all my answers... Guess your a fair ways ahead of me on this JK thing.
I will look into mounting options then, and if 2psi fills four 37"s then there is alot of volume still in a 10lb bottle.
· Registered
I have this exact same setup pieced together the same way however i only paid about 125 for everything.
The regulator is like $55 new, hose attachments are around $15 at HF. check Clist for a tank, no need to buy new since it is faster and easier to swap tanks than to have it filled.
over $200 for this setup is too much imo. Works great but you are approaching kits that aren't pieced together and that saves a lot of hassle.
· Registered
IDK about the HF hose, though I will be running a HF Earthquake impact gun Weds when my Poly. fixed-flow regulator arrives...
I paid $50 for a hydotested 20Lb aluminum bottle (can get more if your near Houston)
I paid $40 for the Poly regulator
I paid $15 for a hose rated at 130PSI, (heard bad things about cheap hose+CO2)
I paid $ 8 for a HF chuck setup
My bottle is stamped AIRGAS, and AIRGAS is 10min away, so I can swap alum, for alum there.
21 - 27 of 27 Posts
