1 - 20 of 27 Posts
· Registered
So I've been meaning to do this for a while now. Back when I was originally building my jeep I wanted an ARB compressor or a viair system but I decided that CO2 was the way to go for me. Most all tank systems are very expensive and I decided to build my own to save some cash and ended up saving a lot.
The tank:
I got a 20lb all aluminum tank from Beveragefactory.com where it was pre-hydro tested and ready to go. Total cost for tank ~$125 shipped
The regulator:
To be honest I don't know where the heck I got it from but if I recall correctly it was from some Australian based company and was the only one available at the time. Now OffRoadAir offers a very similar non adjustable regulator for much cheaper than what I paid (I paid like $85, cheapest at the time) now they have it for $55. On a side note I would also go spring for the CO2 approved hose because your cheap harbor freight air line may freeze and rupture (lesson learned).
The fill station:
I got my tank filled at a welding supply company (AGL in northern NJ) but I have been told that you can go to some fire supply places where they fill fire extinguishers but not all may do it. I paid about $45 to get my tank filled. They had a 3 day turn around time due to not having filling equipment on sight. Although if you don't care they can swap your bottle out for a one owned by the filler company.
The result:
Total cost was about $225 for a 20lb system. A smoking price seeing as a power tank system is about $430 and even a 10lb system costs $380 without being filled! The system works the same as any brand name system if your on a budget, this is the way to go.
· Registered
I have 37's and usually air down to 13ish and it takes right at 2lbs for 4 tires, if I'm careful and don't over fill. Running 26 rear and 28 front..
· Registered
Thanks for this awesome write up. I just got all the components for a little over $200.
Did you mount yours anywhere in your rig? I'm thinking I might put together a roll cage bracket instead of buying one. plus most of the ones I've found only fit up to a 10lb bottle
· Registered
I need this.
Is it worth springing the extra cash for a adjustable regulator or is the non-adjustable one just fine for airing up/setting beads?
· Registered
I need this.
IMO, no. I just bought the non-adjustable one since I don't care that much. It's going to be a hell of a lot faster filling up my 37's at rocky mountain elevation than my compressor and that's all I care about :rockon:
· Registered
I need this.
Nope.
· Registered
Discussion Starter · #8 ·
On previous wheeling trips I literally strapped it in using a seatbelt in my back seat. lol I have seen a few guys on here with 4 doors make wood or welded up metal holders but I have seen some 20# tank holders but if I recall correctly they were rather expensive
· Registered
Discussion Starter · #9 ·
I need this.
Fixed all the way. all you would need is something like an air regulator from someone like arb that has a gauge and a tire chuck on it. changing regulator flow really wont harm anything. Also with a fixed regulator you can bring air tools on the trail. It has saved our butt a few times having an impact set on the trail for swapping drive shafts and whatnot.
· Registered
Tanks weight actually rest on bumper. Straps are just to keep it from flying out. Raced across the desert and tank doesn't budge. By the way, you can get tank exchanges at Hydroponics stores for $13.00. Here in Vegas they are open 7 days a week and are closer to my house than welding supply places.
· Registered
Another option for tank fills are places that service fire extinguishers. Some, not all have equipment on site to fill the tank and will usually get it turned around in a day or so.
· Registered
i paid $299 on amazon for my 10lb powertank kit. Hose, adjustable regulator 0-200psi, mounting bracket and tank. I was gonna go the cheap route, but in the end I would have only saved 30-40. Not worth it in my opinion
· Registered
2 door 2010 JK sport
No clue on what your system contains... but I just priced a 20lb system for $216 + S/H (tank, boot, 30' hose w/chuck, regulator). I'll go this route if it doesn't work out with the guy selling his setup.
· Registered
So I calculated out the cost of everything
125 for the tank
55 for the regulator
43 for a 30 foot hose
then if I wanted a mount, thats another 40-50
Total w/out mount=$223
Total w/ mount = $263
This is not including shipping
Poly sells this
http://www.polyperformance.com/shop/Poly-Performance-CO2-Kit-p-57.html
Complete kit, with mount, for less. Granted, it is only a 15lb tank, but nonetheless. Not trying to knock your write up, but it just seems it would be easier to place one order from poly and get everything you would need. No?
Anyone know of where one could source the needed parts for cheaper?
· Registered
125 for the tank
Poly sells this
Their regulator is $40, a used 20# tank is somewhere around $50, a 25' hose is usually about $25. Mount? Highly debatable, anywhere from $15-$150..So if I went and did it, I'd be spending about $115 for another beverage tank setup..
Poly is basically selling the beverage tank setup; but with a new tank, where the OP is saying "save a lot" is when it's being compared to something like a Power Tank. Which you're basically paying for a nothing-special tank, but a high end regulator, hose and gauge. But many people don't need the high end stuff. IMO his write-up is spot on for what 75% of the co2 users actually need; and 15# to 20# tank is a pretty decent jump..
· Registered
Where did you purchase your used tank?
I guess I need to keep shopping around...
And polys 40 dollar regulator appeared different from the other constant flow regulators I have seen for CO2 tanks, I didnt think it would work for this type of system.
· Registered
This really only applies to Canadians.
Something I found when looking around for systems, was that I was going to pay a boatload and then some for shipping the tank itself. The company listed above (in OP) was $157/163 for the 15 & 20lb tanks. Ended up looking around different Canadian sites, and found these guys. The tank is still comparable at $137, and shipping was going to be $26 (and that's me going from one end of the country to the other). They also have a decent adjustable regulator, however passed on it due to the size.
http://www.ontariobeerkegs.com/20lb_Co2_Tank_p/alum20.htm
This may or may not help someone.
· Registered
The fill station:
Holly Sheet! Last time I checked I could get my tank filled, a beer and a lap dance for that!
1 - 20 of 27 Posts
