i'm looking for a 2 inch full budget boost just so i can run larger wheels and tires. So if you got something let me know!!!
bb
I dont have one for sale, but i did just put a used one my jk 2 dr. Was fairly easy with a couple of buddys. only needed the spring compressors for the rear. The front axle had plenty of drop to get the springs/pucks out and in. With the rubicon shocks, made the ride much more stiffer(like jeep a should be). the stock oem shocks are very mushy (like a car).
You should have no problem finding a nice used BB, since a lot of people get BB's then end up getting the fever to go higher and higher!
My steering wheel only moved a slight hair with the 2" lift
Rough Country has a 2 1/2 " lift for $139.99
Check them out, Chad Enochs is a great guy or also try Teraflex, JoeT here, good luck.
