I recently had a ring gear failure on my Dynatrac prorock XD-60.
I found several teeth have cracks in the same location around the ring.
Has anyone heard of Dana having defective gears?
NH
Are you sure those are cracks? It looks like if they were, they would be catastrophic failures already.
Multiple teeth have failed on the tip. That’s odd. Some odd contact, deflection of the carrier, or contamination? Run out of oil or get water/metal chips in it? Some fracture point lines look like immediate catastrophic fractures and some look more gradual with evidence of crack propagation over time...
I heard a pop when I pulled out heading to work, I didn't think much about it until I arrived at work. When I got out I smelled gear oil, the whole back of the jeep was covered. There is a small hole in the cover, i assume that was the pop noise that I heard.
Due to my job I make a walk around inspection prior to driving always. It had no leaks prior to that morning.
