I guess it’s time to start a build thread, since I went and tore the Jeep apart. I’ve been collecting parts for this build for the past few years, so I probably have at least 80% of what I need to complete it. The big ticket items I have and should keep me busy for a while. The rest is mostly stuff I need to get the build rolling along to figure out. Drive shaft lengths, axle lengths, brake lines, fuel lines, exhaust, etc.
I’ve also never named a vehicle, hell, my old dogs name was Dog, so we’ll just call it the blue jeep build
Anyway, the plan, here’s what I want to do. Starting with a 2010 JKU Sport.
LS conversion with a LS3/525 – , RPM Extreme kit
6l90 w/2800 stall converter, Winters shifter (hits all 7 detents in the trans), Twist Machine paddle shifter
Hero 3 speed transfer case 2.78/4.33 , VSS in tail shaft housing
Rear axle-72.875” wms/wms, JRat 3rd , RuffStuff housing, 40spline ARB, D70 5.13 gears, Solid 40 spline spindles and hubs, 13”Wilwood rotors/ Aero6 calipers, coilover/bypass mts.
Front axle- 73.25”wms/wms. JRat 3rd , RuffStuff housing, 40spline ARB, D70 5.13 gears, Crane C’s and knuckles, Solid 40spline spindles and hubs, 14” Wilwood rotors/Aero6 calipers, coilover/bypass mts
Trail Ready HD17RC wheels and 45x14.50TSL/SXII’s
Hydroboost w/1 5/16th master cylinder
Howe Full hydro steering
32gal Fuel Safe cell sunk down into floor behind axle
Full cage, through dash, incorporating the seat mounts and upper mounts for the CO/bypass F&R
PRP- Podium Elite seats, 42” matching Bench seat, Schroth Harnesses
F&R double triangulated 4-links (rear is easy, front is going to take some work……………a lot of work), minimum 6” up travel (I want more if I can move enough stuff around), ~3.5” lift
Other misc stuff to include:
Line lock for the parking brake.
No wheel speed sensors, will use a Dakota Digital signal conditioner off the rear output VSS of the transfer case to feed the speedo signal.
ABS shit removed. I believe the brain box has to stay but the pump and all the extra lines can go.
EVAP shit removed.
Cruise control will be done through a remote mounted Rostra switch, due to the clock spring issue with full hydro steering.
EVAP shit removed.
