1 - 9 of 9 Posts
hey guys noticed something weird and idk whats going on. so my blinker on the left flashes normal on the dash but i flip to the right and it double times. just weird either ive never noticed it or somethings gone screwy...:cwm13::cwm13::cwm13: any tips???
Usually happens when a bulb is burned out or one is disconnected.
Look for a light that's not blinking on the side that's blinking fast.
It usually means there is a burned out bulb, or a bad power/ground connection.
Or... You're low on blinker fluid on the right side. :)
Always been a bad bulb on my jk.
Gunnery Sergeant USMC (ret)
I assume you are still running stock turn signals? Usually a bad bulb somewhere which tells the system no resistance on that side. Or some shit like that. Change the bulb and you will be good.
thanks guys, found the "bad bulb"... it was weird the brake work, the reversed worked but the blinker didnt work. i lucky had a whole wiring harness left over from when i had to replace the tail light. probably some dirt stuck in the connector cause i swapped bulbs and it didnt work.
1 - 9 of 9 Posts
