Nice (Have the same color on order)How was the install and did you end up using the Cam bolts or did you opt to use adjustable control arms...BTW how is the ride on highway/streets...Thanks...
Looks good, are those 35s?
Yeah it was the basic kit....springs, shocks, adj frnt trac bar, rear trac bar bracket, brakeline brackets, etc...Hey, looks good! Did you use the 3" econo lift if not then which one? I'm planning pretty much the same route and with 35's on stock 18" wheels (Sahara).
I have the Basic Black Diamond AT shocks on mine and I really like them. I think he had to get some different ones because one set of the BD's were not in stock.which shocks did you go with? i'm probably going to go with this lift too since there's no way i can afford the PP kit. just wondering which shocks to go with. where did you get the lift from?
oh and i got the lift from 4wd hardware it was the kit that didn't include shocks anywayswhich shocks did you go with? i'm probably going to go with this lift too since there's no way i can afford the PP kit. just wondering which shocks to go with. where did you get the lift from?
