1 - 1 of 1 Posts
I just got my Bestop Soft Doors and needed a mirror mount so I could use my American Outlaw Mirrors I already had.
The American Outlaw mirrors slide over the door hinge when the door is off so I needed something for them to slide over that would bolt up to the soft door.
The Bestop doors have a mounting plate so you can bolt on older style TJ mirrors to them, but I had a better idea. You could probably use this mounting location for other brands of mirrors or some other kind of homemade brackets also.
I welded a 3/4" rod to an L bracket I bent, drilled them out to fit the door hole pattern. A little grinding and paint. Ta-Da !
You can see the holes in the door skin. There is a steel plate behind there.
It was about 130 degrees in the driveway so the paint is baked on.
Look like they belong there.
Bad picture, but they work perfect !
1 - 1 of 1 Posts
