Why do we have a bearing retainer on the rear axles if it's a tapered bearing? The retainer isn't even up against the bearing. Just a PITA when a seal goes bad.
The 4 bolts and plate hold the bearing in. The retainer ring holds the axle in the bearing.My bearing retainer is not pressed on against the bearing. The bearing has play in it. Roughly 1/16-1/8" of play on the axle. 4 bolts hold the axle in.
Seems to be that the 4 bolts seat the bearing on the race inside the axle tube.You DON'T have a retainer on your axle?
Should look like this:
See that ring next to the bearing, to the right? If you don't have that your bearing will fall off...
The retainer slides through the bearing race. It can't hold the axle in place.The 4 bolts and plate hold the bearing in. The retainer ring holds the axle in the bearing.
How much space is there between the bearing and the retainer ring, on your axle?
How? It slides through the race. If the plate with the 4 bolt fails, your axle is coming out.It's an added measure to keep the from pulling out while you're driving down the road if the bearing fails. It doesn't have anything to do with seating the axle or keeping the axle from going past the race.
Yes. But providing the retaining plate is not failed that retainer isn't sliding through there. The race could never hold the axle in anyway. The race would pull right out.How? It slides through the race. If the plate with the 4 bolt fails, your axle is coming out.
Gotcha! Thanks! Hiding in plain sight! LolYes. But providing the retaining plate is not failed that retainer isn't sliding through there. The race could never hold the axle in anyway. The race would pull right out.
If the bearing seizes and you spin the bearing that retaining ring will keep it on the axle so the plate can keep the axle held in.
Well technically, that's not true because you have rear disc brakes. The caliper and rotor will keep it from coming out unlike a drum brake application...but the bearing retainer keeps the axle from trying to walk out, yes. If it fails..you're going to have to do something about it pretty quickly, however you'd probably have more problems than just that if you managed to destroy that somehow. It provides enough tension on the tapered bearing against race to let it spin freely..but not too much that the race wants to spin in the housing [destroying the housing].How? It slides through the race. If the plate with the 4 bolt fails, your axle is coming out.
Yes, I get the brakes and rotor thing. And I also now get if the bearing was to compltely fail and wanted to spin off the axle the retainer is there for a back stop per say.Well technically, that's not true because you have rear disc brakes. The caliper and rotor will keep it from coming out unlike a drum brake application...but the bearing retainer keeps the axle from trying to walk out, yes. If it fails..you're going to have to do something about it pretty quickly, however you'd probably have more problems than just that if you managed to destroy that somehow. It provides enough tension on the tapered bearing against race to let it spin freely..but not too much that the race wants to spin in the housing [destroying the housing].
Yes, the plate is what holds it all together.How? It slides through the race. If the plate with the 4 bolt fails, your axle is coming out.
Some axle shafts are held in place with only a little c-clip on the inner end.It just seems like a lot of load for that plate with the 4 bolts.
I am familiar with this setup. Never really paid attention to the JK setup til this weekend and staired at it thinking, this is corky!Some axle shafts are held in place with only a little c-clip on the inner end.
I guess better than having to take the dif cover off to get the axles out.I am familiar with this setup. Never really paid attention to the JK setup til this weekend and staired at it thinking, this is corky!
They've been doing it that way for years. My 1972 Plymouth is essentially the same setup..it's nothing new.I am familiar with this setup. Never really paid attention to the JK setup til this weekend and staired at it thinking, this is corky!
