1 - 2 of 2 Posts
Hi all:
I've got a bug in my wiring somewhere so I plan to bypass the ignition's engine-start function and install a push button.
Everything works when the ignition is on, but nothing happens when I try to start.
I'd like to use the existing starter solenoid and relay fuses and make the connection.
Can anyone offer assistance on where I'd need to connect the new starter button?
Thanks,
JLM
Discussion Starter #2
Well, I must have a much larger problem...
I pulled K3 (starter motor) from the main fuse panel , and with the ignition on I have no hot on any of the 4 positions.
So even if I do a push button to start the JK will just drive the starter but never run.
1 - 2 of 2 Posts
