No more oil bottles bouncing around the back of your car, truck, suv, boat or 4x4. The Quart Crate neatly and securely organizes your extra automotive fluids. Fits great and out of the way inside your trunk, behind a bench seat, or anywhere you can fit it.
Constructed from high quality, 16 gauge steel, the Quart Crate keeps your oil, ATF, power steering fluid and any other automotive fluids secure. The Quart Crate's weight-saving design doesn't bog down your vehicle and even makes it simple to carry by hand.
CNC precision cut and bent to provide a snug fit. Features a clip in style hinge on one side and includes two bolts and two wingnuts for quick, easy, one-handed quart retrieval.
Fits all standard-sized quart containers including Mobil 1 and other similar shaped Mobil products. Non-standard oil container models forthcoming.
Can be hard-mounted to your vehicle using simple tools such as a drill.
Dimensions- L: 15 5/8" x D: 4 3/8" x H: 9 7/8"
Other designs forthcoming. Dimple die versions available soon. Bare steel must be painted or powdercoated to prevent corrosion.
PRODUCT LINK Starting at $59.99
