Does anyone know if it matters which terminal the wires on the pressure switch are connected to? In other words can they be hooked up incorrectly or doesn't it matter?
Sent from my Droid using Tapatalk
Most pressure switches just complete a circuit so it "usualy" does not matter. I like to use them to switch the ground in case it internally ever does switch to ground. I also use them to ground switch a relay unless i KNOW for certain that they are rated to handle the amps. I know the Viair ones are clearly marked 30A
Nope, dont matter which way you plug them on. :smokin:
