Incorrect. Viscosity is a tricky thing.
Unless you drive in one of the hottest climates in the country/world (AZ, NM, Baghdad, etc.), you should stick with 5w20, the manufacturer's spec.
Yes, you can modify the game plan and change this, and you may not realize immediate changes, but there are a lot of factors that go into a manufacturer's specification for oil viscosity:
* Thermal break-down
* Circulation speed
* Engine block/Cylinder sleeve material
* Rotational mass of engine components
* And many others...
In my opinion, and after having built engines for years, I would recommend 5w20, and would highly recommend a full synthetic oil (like Mobil 1) for maximum oil and engine life.
One point of mention regarding synthetic oil use. Even if the synthetic oil manufacturer states you can go 5k, 7.5k, or 10k, without an oil change, that you still need to change your oil filter every 2.5k-3k miles, as the filtering properties of the oil filter are not extended due to the use of a better oil. If you don't, the filter will allow dirt, etc. through to contaminate the oil, and will cause premature engine wear.
Hope this helps.
RC
