1 - 19 of 19 Posts
I'm installing a Poly steering correction kit and I don't think my Full Traction trackbar is gonna be able to adjust short enough to work. I would definitely prefer someone that's close to where I'm located, which is Woodland Park. Colorado Springs would be ok, though. Let me know what you want for it. Thanks.:beer:
Discussion Starter · #3 ·
Thanks man. If nobody from Colorado chimes in, then I might take you up on it. I actually grew up in New Orleans and then McComb, MS. Been thru Gulfport more times then I can count.
Got one in nocal if u don't get one local
Cool man, let me know. I have only lived here for a year, I moved from east NC so I'm still a transplant here. It's nice down here except for tue heat, lack of wheeling spots and occasional decimating hurricane ha.
Sent from my iPhone using severed monkey feet.
I'm in lakewood, I have a stocker that I'm not particularly attached to. PM me and we can work somthing out, I might want ur full traction one, I went out today for the first time on my new set up (OME LT) and hit my pro comp track bar on the front diff cover...Not familliar with the full traction bar but if it has any contour to it then it might could help me....either way I don't need my stocker bar....
Discussion Starter · #8 ·
Thanks. I won't know till tomorrow afternoon, after the kit arrives, but my FT trackbar definitely has a good size curve in it. If it won't work with the correction kit, I'll let ya know.
ya I'll check back tomarrow evening, Like I said I don't need my stocker so even if u don't wanna part w/ urs it's all good but if it's not gonna do you any good then I would be interested....lemme know:)
Discussion Starter · #10 ·
The trackbar ended up fitting...barely. There's still a chance I may need to get an OEM trackbar, because mine only has 1/16" clearance on part of the TB bracket. Since I'm installing a bunch of other stuff, it will probably be atleast a week before I can get out and see if everything is ok. If it rubs, it's yours.
I've got front and rear if you need it.
WERD-DUP, if u need the stoker let me know and if u wanna part w/ urs I'm sure we can work it out. lemme know, good luck
I have a buddy that is replacing his OEM for an adjustable tomorrow on his '10 Rubi JKU. We are in Falcon.
Discussion Starter · #17 ·
Thanks for the offers. If my new bumpstops get here tomorrow, then I may get this thing done on Saturday. If so, I should know if I need one by Sunday.
Hey I just thought I'd check back and see if you got out this weekend? If so how did ur new setup work out? Are you needing a stock bar....I saw the full traction bar and it would definately help me out if you can't use it I'd like to know what you would want for it. I have my stocker in the garage if you need it lemme know. If your all taken care of then no problem...I also have a pro comp adjustable on my jeep now that gets pretty short, I used it with my TF 2.5" BB, food for thought.
1 - 19 of 19 Posts
