All 9 of mine have load range D stamped on the side.all of us running humvee 37"s are running E range tires.
I run 25 PSI and its fine
x2 for me with my Toyo's. Heavy? Yes. But very round, easy to balance, and drive great.E rated tires are heavy thus have a negative effect on fuel economy due to the higher unsprung mass.
I generally run my Toyo OPMT at 28psi, to get more miles to the gallon on longer distance highway rides 32psi, offroad down to 12-15psi. They balance nicely and too early to tell for me regarding wear.
Mine have done fine. This is at 15 psi.Fine on road, but offroad toyos don't bag out worth a crap.
Also can't complain, work well on road and off road in the rocks and mudMine have done fine. This is at 15 psi.![]()
Toyo's need to be aired down to 10-12 psi, without beadlocks, and about 8 with -- they'll do just fine and will hang, if not outperform, MTR/K's all day long. I run 28 psi on the highway, rotate through all 5 every 4,000 miles, and have 68,000 miles on my 35" Toyo's. They're starting to chuck when I wheel but they've got plenty of miles left. Just make sure you like them before you buy 'cause you'll have them for a while.Fine on road, but offroad toyos don't bag out worth a crap.
That's my problem. I have them in 33.5" (295/70/17) and wish that I would have just picked them up in 35's from the beginning! :bawling: I have almost 30k miles on them and they barely look half used!Just make sure you like them before you buy 'cause you'll have them for a while.
Merlin knows he goes to the mall Daily with themx2 for me with my Toyo's. Heavy? Yes. But very round, easy to balance, and drive great.![]()
