So, my 2008 has had the issue for literally years now, but has been getting worse in the last 6 months or so. I've read all the "use this filter", "use this oil" threads and I've tried them all with no luck.
Here's my observation. Maybe I'm way off, but it's just a thought.
Everyone says it's a dry start issue. I'm not sold it is. The reason I say this is because if I use my block heater overnight, it NEVER dry starts. Now, I know the primary job of a block heater is to warm the engine coolant, thus warming the engine.
The concensus is that the dry start issue is because the oil filter drains back into the crankcase, and a filter with a good anti-drainback valve will cure dry starts. If this is the case, then what does a block heater have to do with the oil filter? It isn't keeping oil in the filter. I agree that it is technically warming the oil, but....
Maybe actually warming the oil allows it to travel to the valve train quicker? Could, but then why do some who switch to 5W-30 report less clatter? It's a thicker oil, and shouldn't travel as quickly.
So, is it possible that the noise at start up is actually what's referred to as "piston slap" by most GM Vortec owners? Cold temps = more clearance between engine components. Engine warms in the first 2-3 seconds after startup, and less clearance.
I can attest that the dry start issue is directly related to temperature. I live in a cold climate, and when it's below zero, my JK let's me know by clattering like mad. I never hear it if the temps are above 40f.
So what are your thoughts? Why would plugging it in prevent dry starts?
