1 - 8 of 8 Posts
I need to know if the angle position sensor is built into the clockspring, OR, is the angle position sensor a seperate part that attaches to the clockspring ?:confused::confused::confused:
I am having my clockspring replaced sometime in the next few weeks:bawling: for several cruise control codes and the air bag light comming on and off randomly:shaking:.
I want to replace the angle position sensor also if it is not built into the clockspring.
much Thanks !
:beer:
from the factory service manual
The clockspring for this vehicle is secured near the top of steering column below the steering wheel. The clockspring includes an intergral internal turn signal cancel cam and Steering angle sensor that are both serviced as a unit with the clockspring.
U da man !
I REALLY need to get the comlpete set of factory service manuals AND the wiring diagram manual !!!!
Warranty?
If the dealer said that it is not covered, take it elsewhere.
U da man !
look on ebay and the wiring diagrams are in the factory service manual
when i had my center console out i thought i saw the air bag control modules mounted to the top of the transmission tunnel.
I think they are under the passenger seat.
But I was told I need a clockspring and it is in the steering colum.
I have also heard that there is some kind of controller/switch that is for the drivers airbag and the cruise control on the steering colum and maybe that is what you saw??. I just wish I could get it comfirmed that it really exists cause maybe that is what is bad and NOT the clockspring??????
i can tell you for sure that there are two boxes mounted on top of the tunnel under the center console on my 09x marked with warnings about air bag module. the center console has only 4 bolts holding it in.
1 - 8 of 8 Posts
