Aluminum Armour???
4758 Views 63 Replies 18 Participants Last post by  Broncojohn
In an attempt to get some technical discussions started and a topic on Jeeps I have a question?
I am all about reducing weight on my Jeep and most of the armor that you buy for Jeeps is really heavy steel. These jeeps have a hard enough time pulling their own weight without having 1000lbs of additional weight added in bumpers, shids, rockers, etc.
I have often wondered why there aren't more light weight materials used for some of these items.
I understand that aluminum is not as strong as steel and will not take the abuse steel will (i.e. skid plates).
With that being said, I would think that items such as bumpers could be made from aluminum if steel inserts were used for specific parts such as steel winch plates, and steel inserts that would be used as tow points. IF these pieces were reinforced and attached to the frame, would they be strong enough?
There are obvious areas of concern such as tire carrier mounting, shackle mounts, winch, etc.. I would think these could be worked around with the right design and the weight saved could be in the hundreds of pounds.
Unfortunately items such as skids would probably not be a candidate, since the skids on JK's span such a large area and would not withstand the forces applied if they were aluminum.
But rockers could theoretically be made from aluminum with replaceable steel skins that could take the abuse and when the steel skin was beat up bad enough, take it off and replace it?
This may all be pipe dream based on the cost of engineering and producing something out of aluminum (i.e. the cost would likely be very high), but like I said at the beginning, I just wanted to talk Jeeps and this is something I have been kicking around in my head for years....
1 - 20 of 64 Posts
teraflex makes their sliders out of aluminum.
Ahh, well see I didn't know that, thats good info...i'll look into those.
Its more a cost and durability thing.
You CAN make aluminum harder, and so forth, and use steel inserts, etc...but, the more TIME it takes to make something, the higher the labor costs...and, as the MATERIAL is more expensive, the material costs also go up.
Machining and other procedures would make aluminum parts cost prohibitive.
If we had a cheap source of titanium, that would be an alternative perhaps.
:D
I think the only way to get people to consider buying something that expensive, especially considering the doubts they'll have about its durability, etc...would be if it were SO MUCH lighter that the armor didn't sag the suspension, reduced the COG off camber, and increased their mpg ENOUGH over what a steel armor alternative would.
IE: What's the payback period?
Example: If the Al version cost another grand...but you saved 1 mpg due to weight savings.
If I got 16 mpg with steel, and 17 mpg with Al...at $2/gallon to make the math easier...so I'd need to save ~ 500 gallons to break even.
So (x/16) - (x/17) = 500 gallons....with x being the number of miles you have to drive to break even.
:D
That's roughly 136,000 miles to break even...not that compelling.
To get the payback down to a year...let's say at an average of 18,000 miles/year...I'd need to get way too many more mpg out of the mod than is feasible.
So the market would be "cost is no object weight reduction fiends"...a limited niche.
TeraFlex sells aluminum sliders...I haven't seen them in action. I've HEARD they hold up...but the sample size is very limited...so I don't have a context for how hard that is to do, etc.
I've SEEN Al skids, and, they gouged and were damaged like crazy...so I was not impressed...but, I don't know what grade, etc, of Al was used, etc.
T-6 alloy, etc...is pretty good stuff...if anyone used it for skids, they should pipe up.
:D
GOOD LORD TEEJ - Another very informative answer! :beer:
If the companies read this thread... ARE YOU LISTENING TO US?
Thats what I would call an above and beyond answer Teej :D Good points.
As I said in my post, cost would be the down side to this.
I looked at Tera's stuff online. It looks like a nice design, as for how it holds up depends on how it is used I imagine, some are harder on stuff than others.
The only problem is paint does not stick very well to aluminum unless a strict process is followed. I do not know that process myself, I just know one exists and certain paints need to be used. I have heard of the Teraflex ones having the paint peel off.
I do not have aluminum skids but my sliders have aluminium skins. At first I was worried they would just bend to easy with a direct hit. I ended up taking a direct hit and they actually held up pretty well, I was surprised. They are gouged a little but it was mostly only the clear coat on them that scraped off. YOu can barley see it in this picture but it is towards the rear of the slider on the aluminium above where the scrapes are on the steel
In my opinion I think that it is not quite as soft as people are afraid it is. I would be really curious what a aluminum underbelly skid looked like after the full weight of a vehicle was dragged across a sharp rock.
It reminds me of what some XJ guys where doing for some armour. They where using plastic!! Yes, plastic (well, not exactly plastic but I forget tghe actual material name it was being made from). They found it was like butter. It actually wouldn't gouge as deep as you would think becuse it slid so well. Then when it was beat up they would just replace it. They were mostly using it on Quarters though.
I have been thinking of that for a skid. Not sure what the weight or cost differences are though
Here is an interesting thread on nylon and VHMW skids, they start talking about it on about post #960
http://www.pirate4x4.com/forum/showthread.php?t=375081&page=39
On that same thread I just linked above, post #1018 he used aluminum for the boat sides :smokin:
from Pirate4x4 said:
The boat side skids are made from .200" 7075 aluminum.
Geargoyle told me a neat trick on how to bend the aluminum.
Draw a line with a Sharpie where the bend is to take place. Then, with a rose bud, heat the aluminum on either side of the line. When the line starts to become faint, make the bend.
I think companies could do a lot mroe to save weight. Some of these companies have such a high margin anyway, why not put a little effort in and stand out from the crowd.
If you look at desert trucks for example there are holes drilled everywhere and all sorts of other materials used without drastic increases in cost.
Keeping a Jeep light would save more than just fuel costs. It would climb better, side hill better, save brakes, and breaks. Repair costs would be lower.
Bumpers for the JK would be easy. An aluminum bumper would simply surround the steel winch plate and factory tow hooks that all bolt to the frame. With a stubby bumper it would never really contact any rocks anyway.
rear bumpers could by made high clearance and light. Ditch the heavy swing aways and concentrate on reinforcing the tailgate with an extra hinge and some plate to add stiffness.
There are all kinds of ways to keep the weight down on these things, its just easier to build it with heavy steel and call it "hardcore"
Plastic huh? Wonder how much plastic material like the stuff they use for cutting boards would cost. I have a white cuttin board that is about quarter inch thick and that stuff is indestructable even after many hours of chopping food on it and I can see that it would be slick enough and light weight.....interesting consideration
Allied Racing is using a similar plastic on it's beadlock rings.
Anyone know what the factory bumpers weigh?
Consider for a moment that wheels are made from aluminum. My stock alum wheels have scraped some pretty good rocks and taken it rather well. Bodyguys wheels are buggered up and I have seen them riding on the rim and they are scarred, but have held up well.
When you think about it, wheel mfgs could gear up rather easily to make bumpers since they already have the machines that are used to mfg aluminum wheels...
YAh, take a look at that thread I linked above. They have a short discusuion about it. Looks like there was some comments that the Nylon was supposed to be nearly as strong. That may be what your cutting board is made of. They were using 3/4 inch
The amount that I see aluminum used for other uses and other motorsports without prices being outrageous I don't see why it can't be done here.
Even if you use KerryP's wheel example. Each wheel is not outrageously expensive. That same amount of material could be cast/forged or assembled to make bumpers, etc.
Once problem I see is that there are so many other things made for Jeeps from steel that have no real reason for it. (like CB racks, light tabs, etc )
I couldn't agree more. I think so much stuff for the Jeep come from the garage welder. Like you said, it is just easier to weld up a bunch of plate.
Also, so many of the oldschool "hardcore" wouldn't buy something cuz it wasn't steel so manufactures would shy away from it.
I am very interested in light weight/ high strength. I am glad this topic came up. I just feel like if you want something good offraod, it would be better if it was 1,000 lbs lighter. Also seems you would take less drive line damage and the hits would not be so hard. YOu wouldn't need 1/4 steel if you didn't have 10,000 lbs crashing down on it...
It is kinda funny to me...I come from more of a auto racing back ground, I had an XJ to play in but it was not my main focus. Anyway, everything was about saving weight. I mean, even switches and knobs where made out of light weight material or drilled out.
Jeeps are the opposite, it is all about adding weight and "strength". like you said, even the cb mounts are made from steel, lol :shaking:
In motorsports they are able to design surprisingly strong parts from lighter weight material such as aluminum. Not sure why it can't be true with Jeeps. In the end I don't think the cost is that big of deal, I think it is th eknowledge of Jeep parts buiolders in general but mostly the buying publics reservations on non steel items. I think there is a lot of "no replacment for displacment" types driving Jeeps if you catch my drift.
MAn, wouldn't it be nice to have a Jeep lighter then stock AND stronger then stock as opposed to a beast that weighs in at a couple grand over stock design out on the trail? :beer: :beer:
I also raced cars and motorcycles and have been harping on this topic with the Jeeps for over a decade. (and being bashed for it by those that think it must be heavier to be stonger and not be stranded on the trail.).
I was happy to see synthetic rope come out for winches, happy to see buggies finally lighten up, a plastic grill on the JK etc.
Now if we could just figure the rest of it out. This is half the reason I have not changed out my bumpers and skids yet on the JK. (never did put heavy skids on my extremely modified TJ just for the weight reason)
1 - 20 of 64 Posts
