Very pleased to introduce our new Alloy USA Heavy Duty Dana 30-44 Ball Joint kit..
Here is the marketing part...
You know that the factory ball joints are just fine for the factory set up, but who drives around in a factory stock Jeep anymore? When you are adding larger tires and therefore more stress on the components, the stock ball joints tend to fail prematurely. The Alloy USA heavy duty ball joints were designed for vehicles with lift kits and larger then factory tires to eliminate the stock weak points and make improvements that will help the off-road enthusiast. No nylon inserts to wear out.
■Alloy USA – 5 year limited warranty
■Fits 07-13 Jeep Wranglers
■Fits 99-04 Jeep Grand Cherokees
■Made from SEA 4120 and 4140 heat treated high grade steel
■Grease fittings (not found on factory application) allow for continued maintenance
■Ball joints can be greased after installation
■Complete set of 4 pieces, 2 upper & 2 lower ball joints
The Alloy USA heavy duty ball joints have been designed with a low profile (grease) zerk fitting for regular maintenance, a feature not offered on factory replacement parts. The plastic inner insert has been replaced with a high strength steel socket system. This design greatly increases ball joint strength and durability. This is a “Must” for lifted vehicles running any tire larger than stock applications. Ball and socket are assembled using an exclusive threaded preload system to ensure precise tolerances for prolonged joint life and precise steering. The ball and shaft are constructed from industry leading SAE 4140 Chromoly steel. Alloy USA ball joints are industry leaders for durability and strength
If you got questions let me know!! MSRP is set at $199 for a complete set of (4)...
