I did notice that as well...Your caster is WAY low. You should bump it up to around 4-5 degrees. All the other specs look just fine, the only thing that stands as is the caster.
I guess that's what I get for assuming.RK numbers are only an estimation; at least that's what they say about it in the install manual.
I've got the same thing. Every thing is good as far as specs go but I think my passenger unit bearing is going out. I can feel it when I cornerNeed some opinions...
I have a small amount of wandering but everything else feels pretty good.
