can you post a few pics of how the compressor mounts?
So you did the install? How long does it take to air up your tires?I paid $1,200 for the complete kit.
It came with everything needed and the Yorks are brand new. The push together air lines and fittings make the install easy.
It also comes with something they call a "York Saver". Its an LED that gets mounted in the insturment cluster. When the York kicks in it turns green. If it runs for longer than 15 seconds the LED turns red to let You know theres a possable problem, like a blown air line, so You dont burn up the York.
I have some more pics of the install posted here in another thread. I made a thread for My OBA and SwayLOC install.
It seems like a lot of money but its a well thought out system with really nice parts. I pieced together an OBA set up on My old YJ years ago. It was a bulky set up that wasnt half as nice as this one!
IMO it isnt worth piecing a kit together Yourself when You can get everything You'll ever need with one phone call.
And their customer service is top notch! I called them and talked to them about it before I bought it. Super nice Guys!
Thanks for the info Matt.Yup, I did the install Myself. It was super easy!
I installed the "York Saver" and the OBA wiring harness in less than an hour after work one day. Then I mounted the compressor and did the rest of the install another day. The rest took about 2 hours. That includes making trips to the garage refrigerator to get another beer
I haven't had a chance to head north and do any wheeling since I installed it so I cant comment on how fast it will air up tires.
When I talked to Him He said that they designed their OBA system around their AiRock suspension. They use a small 1 gallon tank which fills up very quickly. That makes the York run less, which creates less heat in the York and less oil in the air. It also creates a higher air pressure compared to other systems that run larger tanks.
The larger tanks may have a larger burst of pressure at the start, but once the tank drains down the compressor has to fill the large tank and fill a tire making it slower.
I hope that makes sense!
I'm sure the Guys at ORO can explain it a lot better than Me!
Dont hesitate to call them, they are happy to help!
The shocks come with the system and ORO is just improving on the current ones. The shocks are seperate from the airbags. You can use the Airock in hardcore stuff and it will work just fine. Just remember you are using factory control arms and steering.I really appreciate the comments. When you say shocks are they separate from the airbags? Why not the hardcore stuff too? How often do you find yourself using the manual mode to tilt in off-cambers or up really steep climbs?
Chris
