1 - 20 of 21 Posts
I'm working on my OBA system and I'm wondering if any of you had an idea on where I could mount my air tank.
My compressor will be under the hood using Dominions Offroad's bracket. It seems that any options available for the 2007-2011 JKs will not work with the 2012+.
I'm currently thinking about relocating the Evap and mouting the tank there or relocate the muffler and mount the tank behind.
Any thoughts/ideas?
And yes. I searched :thefinger:
Gunnery Sergeant USMC (ret)
I relocated my muffler on my 07 JKU under the driver seat and put air tank where it was. Just pick a muffler that is skinny enough to full tuck up horizontal above the frame rails.
does that make sense?
Something like this:
You could mount a tank between the radiator and engine like the Vair kit does.
I don't think that will work on the 3.6L. The radiator hose is in the way. I have a 2 gal Viair tank that I've been mocking into different locations. Changing exhaust would definitely give you more options. I'm planning on mounting it in the rear cubby and building a gear box over it. It sits about 2" above the floor height if you take the plastic box out.
I know that a circular tank is structurally more sturdy that a square one, but anybody know of another vendor that makes air tanks than Viair??? Maybe with a different shape?
I did about an hour long Internet search and couldn't even find a skinnier 2 gallon. They were either the same diameter, around 6" or fatter. I'm sure you could have one custom made by a decent fab shop, not sure what they would charge though. I think I would depend a lot on which compressor you use. The Viair my buddy has runs 200 psi where my ARB runs 60 psi. The stress on the metal at 60 would be a lot less and a square tank might be practical.
Well.. first problem is finding a decent shop.. I can't even find one to get my truss welded :(
My compressor is running at 150 psi.
Try mounting it to the roll bar behind the light. I used "square" u-bolts and a piece of 1/8" plate. 2 1/2 gal viair tank, and I don't even see it in the mirror.
How would it survive a roll up there? Any pics? I am thinking of mounting my tank on the molle panels sold off ebay that go on the top front of the rear wheel wells (4 door).
Do you have photos of your compressor mounted? I just ordered my 2013 JK yesterday so curious where I'm going to mount. Wanted to run the ARB twin compressor but doesn't sound like there is room?
I mounted my 1 gallon tank in the storage depression in the rear of the JK under the storage platform I made. Everything is inside and out of the dirt.
I mounted my ARB Twin Compressor under the passenger seat.
Very nice and clean install. I wonder if the bigger viar tank will fit in the storage area...
Discussion Starter #18
I haven't had time to install it yet. We I do, I'll post pictures.
Sent from my Nexus S using Tapatalk 2
M
Guest
I rebuilt the factory roll cage fr strength and looks, but in the process I decided to use it as an air tank. The compressor fills it as I walk to the next tire. Fills 4 37 inch tires in 5 minutes. I don't run air tools, just air down and up. Arb compressor mounted under hood direct to battery with switch inside.
1 - 20 of 21 Posts
